Thread: How do I feed power to my 12" car subwoofer in my room |
New member Username: Audiobullies
Post Number: 1 Registered: Dec-07
| Posted on Tuesday, December 11, 2007 - 09:19 pm: |
Hi.. I am needing to know how tdo I feed power to my car amplifier which is hooked up to my car 12" subwoofer in my room with the full 12voltz and the needed recommended amps.. I have the following equipment.. Sony Xplod 1000watt 12"Subwoofer in non-ported box. ICE Power 1400watt 4channel amp Very powerfull Sony Deck rated at high RMS.. All wiring already supplied (Just need solid} current going to the amplifier) Please help me.. Thanks Guys! |
Relevant Product Info
Post Number: 2 Registered: Dec-07
| Posted on Tuesday, December 11, 2007 - 09:30 pm: |
I am already running my sub from the already connected Sony Deck but its not giving me the pump in the loud deep bass that I get in my cars audio systems, yes.. ofcourse the set up is not meant for the room but I need that extra kick of deep bass and pressure that I desire and have the amp to do just that.. I have a relative who powers his amp with a 12volt battery-charger which throws off the correct voltage but I am hoping to find another way of getting good power.. Please assist.. |
Bronze Member Username: Cooltech
Post Number: 12 Registered: Dec-07
| Posted on Wednesday, December 12, 2007 - 12:54 pm: |
A 12v car battery charger would work good.Thats what i would do. |
Silver Member Username: Dmitchell
Ottawa,
Ontario
Post Number: 455 Registered: Feb-07
| Posted on Wednesday, December 12, 2007 - 10:06 pm: |
What's with everyone trying to run car subs on a home stereo lately? |
Platinum Member Username: Wingmanalive
A pic is worth
1000 posts!!
Post Number: 11602 Registered: Jun-06
| Posted on Thursday, December 13, 2007 - 09:47 pm: |
Shabir, you need an enclosure, properly tuned to start. A plate amp (for a powered sub) properly sized connected to your receiver's sub out line. That's the basics. Powering that sub any other way is retarded. Some @holes even bring their car batts inside to use. Don't be included in that statistic. |
