Thread: Completely dead. |
New member Username: Sgtmian
Post Number: 1 Registered: Dec-07
| Posted on Wednesday, December 05, 2007 - 05:14 pm: |
i bought this turntable, which just arrived today. i live in norway, so our plugs are different, but i had an adapter, so i thought it'd be fine. when i turned it on, though, it spun maybe three or four times and then went dead. i think it might be a voltage problem, but i'm not sure. unless it got damaged on the way here. what do you think, is there anything i can do? |
Relevant Product Info
Platinum Member Username: Jan_b_vigne
Dallas,
TX
Post Number: 11820 Registered: May-04
| Posted on Wednesday, December 05, 2007 - 09:42 pm: |
. I know nobody wants to hear this but if there was something you could do, wouldn't you have done it by now? If you open the case, you'll void the warraty. Call the shop where you bought the merchandise. |
Post Number: 2 Registered: Dec-07
| Posted on Thursday, December 06, 2007 - 03:44 pm: |
what do you mean? i was asking what people thought might have happened, and what, if anything, i could do. and the warranty doesn't work outside the u.s. anyway. which is teh über suck. |
Dallas,
TX
Post Number: 11824 Registered: May-04
| Posted on Thursday, December 06, 2007 - 11:15 pm: |
. "which is teh über suck" Yep! |
