Thread: Misc: |
Bronze Member Username: Magfan
Post Number: 55 Registered: Oct-07
| Posted on Wednesday, November 28, 2007 - 07:17 pm: |
Well, I'm a believer now. I've was looking for a power amp to replace a reasonable Rotel..... That was until I unplugged it from the Power Conditioner! I KNOW....you guys said it, but I had good results with my old Cube plugged into the same conditioner. I think the difference was in power supply of the amp. Yep, the Rotel woke up nicely and drives the new Maggies fairly well, even improving the bass end of things. The next step will be to get an electrician out to drop me a circuit just for the stereo/TV. I think this will be more for peace of mind than actual performance. Just for reference, I went and listened to a Krell Integrated. It was hooked up to some up-line Maggies as is my preference, and while it sounded good.......the Ayre CD player is a true megabuck unit, the Krell ran hot. Too hot, so that after about 1/2 hour and nothing radical, I gave up. A couple hours at my house in the summer and that would be the end of Mr. Krell. |
Silver Member Username: Nickelbut10
Post Number: 802 Registered: Jun-07
| Posted on Wednesday, November 28, 2007 - 07:59 pm: |
Leo, I forgot about that upgrade. Im going to try that again tomorrow on my lunch when I can really crank the system. Thanks for bringing it up. |
Silver Member Username: Mike3
Wylie,
Tx
Post Number: 895 Registered: May-06
| Posted on Wednesday, November 28, 2007 - 10:29 pm: |
NMyTree convinced me to unplug my Rogue pre-amp from the line conditioner. It did wonders for my sound as well. I only have the source plugged into the line conditioner now. |
Platinum Member Username: Jan_b_vigne
Dallas,
TX
Post Number: 11796 Registered: May-04
| Posted on Wednesday, November 28, 2007 - 10:37 pm: |
. Everything is on sale when it isn't in stock and you're not buyin'. |
Dallas,
TX
Post Number: 11797 Registered: May-04
| Posted on Wednesday, November 28, 2007 - 10:38 pm: |
. How'd that end up here? |
Silver Member Username: Dmitchell
Ottawa,
Ontario
Post Number: 420 Registered: Feb-07
| Posted on Wednesday, November 28, 2007 - 11:34 pm: |
I thought you were replying to every post with that line tonight... LOL |
Gold Member Username: Nuck
Post Number: 9311 Registered: Dec-04
| Posted on Thursday, November 29, 2007 - 05:44 am: |
You are skipping, JV. Adjust your arm. |
Dallas,
TX
Post Number: 11799 Registered: May-04
| Posted on Thursday, November 29, 2007 - 09:18 am: |
. It's the tracking weight that's off, not the anti-skate. |
