Thread: Ground loop on guitar amp |
New member Username: Hideyourface
Post Number: 1 Registered: Nov-07
| Posted on Monday, November 26, 2007 - 04:28 pm: |
my guitar amp is humming a lot. In my basement, I have a computer, fridge, and my amp plugged into one socket on the wall and some lights in the other. I tried unplugging everything and plugging only the amp into one socket and there was still a little noise, less, but still a fairly annoying amount. Im really not sure what to do, and im really tempted to cut off the safety pin and attach a wire from it to a water pipe like a friend suggested, even though its not supposed to be safe. What else could I do? |
Gold Member Username: Arande2
Rattle your ...
Missouri
Post Number: 2688 Registered: Dec-06
| Posted on Monday, November 26, 2007 - 05:52 pm: |
Is it possible to make a separate ground for the amp? You could run one from the outlet to your own ground that you put in and make it separate from the others. Of course, I have no idea what I'm talking about according to the others on here. They'll help you.  |
Platinum Member Username: Jan_b_vigne
Dallas,
TX
Post Number: 11791 Registered: May-04
| Posted on Monday, November 26, 2007 - 07:16 pm: |
. First, you should make sure the outlet you are connecting to has a three wire lead. Lack of a separate ground can cause as much noise as too many ground points. Then, if you have all three conductors installed properly in the outlet - make certain the ground wire is connected to the ground lug and the hot to hot and neutral to neutral - you can buy a ground lift form any hardware store. . |
Bronze Member Username: Magfan
Post Number: 56 Registered: Oct-07
| Posted on Wednesday, November 28, 2007 - 08:04 pm: |
Conor, While your at the hardware store, get an outlet tester......it will check for all normal errors....hot/neutral swap and so forth. couldn't hurt.... |
Dallas,
TX
Post Number: 11800 Registered: May-04
| Posted on Thursday, November 29, 2007 - 09:23 am: |
. Buy an outlet tester?!!! Buy one? Wait a minute ... You mean not everyone is given one at birth? Oh, wow, man. Heavy!!! . |
Post Number: 67 Registered: Oct-07
| Posted on Wednesday, December 26, 2007 - 07:06 pm: |
Sorry, Jan, Didn't mean to SHOCK you. A buddy of mine had a male cat that was a terrific outlet tester......but the smell was awful. |
