Thread: Amp matching PSB Alpha B1 |
New member Username: Mfaella
Post Number: 1 Registered: Nov-07
| Posted on Thursday, November 22, 2007 - 10:46 am: |
Hi, I'm a newbie trying to build a budget mid-fi system, starting with a pair of PSB Alpha B1. I'm currently looking for a matching integrated amp, for about 500$. Do you think Onkyo is a reasonable direction? In that case, I wouldn't know where to stop on the 9155 - 9355 - 9555 line-up. How big do you consider the improvement in sound quality from one model to the next (or is it just a matter of power)? Thank you very much in advance for any suggestion! Marco |
Silver Member Username: Nickelbut10
Post Number: 744 Registered: Jun-07
| Posted on Thursday, November 22, 2007 - 11:36 am: |
Grab an Entry level NAD or H/K. |
Platinum Member Username: Jan_b_vigne
Dallas,
TX
Post Number: 11771 Registered: May-04
| Posted on Thursday, November 22, 2007 - 12:38 pm: |
. What kind of sound qualities are important to you, Marco? The PSB's are a relatively nuetral speaker with a tendency to show what's in front of them. What the components in front of the PSB sound like, therefore, will be reflected in the final product you hear. |
Gold Member Username: Nuck
Post Number: 9257 Registered: Dec-04
| Posted on Thursday, November 22, 2007 - 07:04 pm: |
Any integrated you put in front of the Alphas will be icky with a dvd player. |
Post Number: 2 Registered: Nov-07
| Posted on Friday, November 23, 2007 - 06:54 am: |
Thank you all for your feedback. Nuck: Can you clarify? Are you suggesting I should get a good CD player first? Jan: I listen to both classical and pop/rock. I don't have much experience in describing what sound qualities are important to me. Generally speaking, I appreciate spaciousness and definition, and I wouldn't mind the sound to lean toward warm and musical rather than dry (though I'm perfectly fine with neutral!). Btw, I'm re-evaluating my budget to 700-800$. |
Silver Member Username: Hawkbilly
Nova Scotia
Post Number: 107 Registered: Jul-07
| Posted on Friday, November 23, 2007 - 07:10 am: |
To Nuck's point, depending on what components you are using to drive the PSB's now, a source-first upgrade may yield far greater improvements in sound quality than upgrading your amplification. And if you are currently using a dvd player as a source, I would agree wholeheartedly. |
Nova Scotia
Post Number: 108 Registered: Jul-07
| Posted on Friday, November 23, 2007 - 07:16 am: |
And to answer your original question, I haven't personally heard any of these Onkyo amps, but I've read quite good things about the A-9555. For the price, it matches up very well to the competition. Here's a link to an article that compares it to a number of other Class T and D amps. http://www.stereomojo.com/SHOOTOUT2007INTEGRATEDS.htm |
Post Number: 9264 Registered: Dec-04
| Posted on Friday, November 23, 2007 - 07:22 am: |
More or less, yeah, Marco. But that is always my advise, source first. However, a good pc setup is often cheaper and more adaptable than a stand alone cd player on a budget. With a big ol' hard drive to run music in uncompressed format. If it's mp3's, then who cares anyhow? |
Post Number: 3 Registered: Nov-07
| Posted on Friday, November 23, 2007 - 08:16 am: |
The point is, both source and amp are crappy now! Source is indeed a (40$) DVD player (how did you guess? :-) and amp is the built-in of a consumer mini. I'd like to upgrade the amp first because I'm eager to enjoy TV + DVDs + CDs through the Alphas, and I need an amp/receiver for that. CD player is next, I promise :-) Interesting shootout. I've also read good things about the A-9555 (i.e., stereophile) and in fact I'm considering getting that one. |
Post Number: 9269 Registered: Dec-04
| Posted on Friday, November 23, 2007 - 09:04 am: |
How did I guess? Have you seen my post count? A solid integrated and a pc setup is easy and adaptable. It will also fit your space, seeing as your pc and stereo are in the same room. |
Nova Scotia
Post Number: 109 Registered: Jul-07
| Posted on Friday, November 23, 2007 - 11:53 am: |
MF, other than Onkyo, what other brands are available to you locally that you could demo in-store, or even better, in-home ? And whatever you get to demo, ask them to demo the amps on the same source/speaker combination. A lot of dealers, if it's not overly busy in the store, will do this for you so you can listen in some reasonably comparative fashion. If you listen to one amp in one room, and another amp in a different room, attached to entirely different gear, you will not really know what is driving the differences you're hearing. |
Post Number: 9276 Registered: Dec-04
| Posted on Friday, November 23, 2007 - 12:25 pm: |
The Alpha's do not demand a lot of an amp. The choice comes down to sound and preference. The newest Onkyo's are better than the previous iterations, or so I am told. Driven by a GOOD INTEGRATED amp, these speakers can, and will make many listeners happy. With a receiver, well, how good is the receiver? I still vote for an integrated amp and pc source. MF, those speakers are on very solid stands already, right? |
Post Number: 4 Registered: Nov-07
| Posted on Wednesday, November 28, 2007 - 02:00 pm: |
Tomorrow I will audition at least the Marantz PM7001 and NAD 315BEE in-store, with the same speakers I have. Unfortunately, the dealer does not carry Onkyo (and is therefore skeptical about them :-). On some forums, I read people declaring the Onkyo A9555 as superior to the Marantz PM7001, in particular as far as neutrality and detail are concerned. Too bad I probably won't be able to audition it around here. Nuck: the speakers are currently just sitting on the tv stand, tv in between. |
