Thread: Basic amp and connection question |
| Posted on Tuesday, July 22, 2003 - 04:47 pm: |
HI I have a Gemini X4 Power AMP, which i think is american made amp, god bless that freedom, and their are just a couple of questions to ask. 1. Both my speakers eltax mill 500, and the amp state; 4 - 8ohms, however it doesn't say if its 4-8ohms norminal, which would it choose, or is there i way to know if its 4 or 8ohms? 2. I also run a Denon AVR-1803 AV Reciever. I use the analog VCR-2 output for the power amp, is the quility suffering? Should i use a splitter for the input instead? Or something else? Thanks Adam C. England. |
Derek |
| Posted on Wednesday, July 23, 2003 - 07:49 am: |
Measure across the speakers input terminals. That impedence, though at DC will give you some idea of the speakers impedence. Why not use the receivers preamp-output so you can control the volume? |
Adam C |
| Posted on Thursday, July 24, 2003 - 09:05 am: |
I have volume settings on the poweramp, also the denon avr1803 only has sub pre-outs. I'm left with either. buying a new av reciever (not likely) buy a av processor, or splitting the phono input, or using phono outs. Which from what i heard i'm losing a small amount of quility. Thanks Adam C |
Derek |
| Posted on Thursday, July 24, 2003 - 01:18 pm: |
I don't use them but try Zone-2 pre-amp outs. You may be able to use a high quality speaker-level to line-level converter. You know the ones used in car stereos... |
| Posted on Tuesday, August 19, 2003 - 05:43 pm: |
i hooked my 4channel amp to my fronts i had all the things i needed and it didnt work when i touched tha wires my speaker went out all 4 of them |
| Posted on Thursday, August 21, 2003 - 11:10 pm: |
I got a second-hand Sherwood power amplifier AM-8500B and a preamp AVP-8500B and am still confused about their specifications. I would be very thankful if somone can tell me such specs. Bach VietNam |
| Posted on Friday, August 29, 2003 - 06:48 pm: |
how can i plug in my amp so it doesn't suck all the juice from my car battery? |
markey |
| Posted on Wednesday, September 24, 2003 - 10:57 pm: |
I have a Punch800, it has 4channel but I only have two speakers.Do I just connet the two speakers to 2 channels and leave the other two without anything?Or is there another way to connect the two speakers using all the 4 channels to get max output. Thanks. markey. |
