Home > Message Board > Home Audio > Subwoofers > HSU VTF-1 vs. SVS 25-31PCi
Author Thread: HSU VTF-1 vs. SVS 25-31PCi
Username: Kbear
Post Number: 26
As the title indicates, it's the VTF-1 vs. the 25-31PCi. Which do you rate better? Which is better for music? I assume both will be fine for movies.
The sub will be part of a 5.1 system, 50/50 music to movies, and music is important! I'm not expecting that either will be a bad choice though.
The 20-39PCi is also under consideration as it doesn't cost much more than it's cheaper cousin.
Thanks!
Relevant Product Info
Post:
Username: Need to Register?
Password: Forgot Password?
Action:
Home > Message Board > Home Audio > Subwoofers > HSU VTF-1 vs. SVS 25-31PCi [ « Previous ] [ Next » ]
