Thread: Help with ohm ratings |
New member Username: Reaper360
Post Number: 1 Registered: Nov-07
| Posted on Monday, November 19, 2007 - 08:00 pm: |
I have a Yamaha HTR 5730 receiver and it's rated at 6 ohms. My friend just gave me some JBL speakers rated at 8 ohms. If I connect the speakers up, will it damage anything? Thanks for your help. |
Gold Member Username: Nuck
Post Number: 9244 Registered: Dec-04
| Posted on Monday, November 19, 2007 - 08:59 pm: |
No issues there, Byron. But if the receiver gets hot, or worse, shuts down, the lessons will commence. |
Gold Member Username: Frank_abela
Berkshire
UK
Post Number: 2529 Registered: Sep-04
| Posted on Tuesday, November 20, 2007 - 12:18 pm: |
All things being equal, a higher rating makes the speaker easier to drive. So you should have no problems there. Of course it depnds a bit on the speakers, but the nominal 8-ohm rating means they don't go very low (which is harder for an amp to drive). Regards, Frank. |
