Thread: Universal remote control for rega mira3 |
New member Username: Mirod
Post Number: 1 Registered: Nov-07
| Posted on Tuesday, November 13, 2007 - 08:10 am: |
What universal RC works with this amp. Thank for your replay. Mirod |
Platinum Member Username: Jan_b_vigne
Dallas,
TX
Post Number: 11728 Registered: May-04
| Posted on Tuesday, November 13, 2007 - 09:01 am: |
. Try a learning remote. |
Post Number: 2 Registered: Nov-07
| Posted on Wednesday, November 14, 2007 - 12:21 am: |
Could you recommend any rearning rc? I tied some learning rc, but they didn't work correctly.(switching inputs did't work) ps:i haven't original rega solar. |
Dallas,
TX
Post Number: 11733 Registered: May-04
| Posted on Wednesday, November 14, 2007 - 08:27 am: |
. No, I can't. It is unusual to find any remote than accepts all codes. You might try calling the Rega distributor. Ask which remote their's is based on. Most remotes for companies such as Rega are not proprietary to Rega but are taken from other companies and Rega tacks on their own codes for particular functions. But you may not be able to have all codes in one universal. That's just kinda life in the land of universal remotes. . |
Gold Member Username: Nuck
Post Number: 9202 Registered: Dec-04
| Posted on Wednesday, November 14, 2007 - 06:02 pm: |
And there will always, always be a function that does not work. |
Gold Member Username: Artk
Albany,
Oregon
Post Number: 5619 Registered: Feb-05
| Posted on Thursday, November 15, 2007 - 07:18 am: |
So buy a Solar...problem solved. |
Gold Member Username: Frank_abela
Berkshire
UK
Post Number: 2516 Registered: Sep-04
| Posted on Thursday, November 15, 2007 - 11:32 am: |
If you look on Rega's site you'll find the Solar remote manual (under Products, then Accessories)which contains all the codes, so youshould eb able to program them into your learning remote. The Solar remote speaks RC5 which is just about the most common language for remote controls. Any learning remote, such as a Pronto should be able to handle this. Regards, Frank. |
Post Number: 3 Registered: Nov-07
| Posted on Friday, November 16, 2007 - 12:04 am: |
Thanks all. I"ll try Pronto. MiroD |
Berkshire
UK
Post Number: 2523 Registered: Sep-04
| Posted on Friday, November 16, 2007 - 12:54 pm: |
Miro The pronto was just an example! I know nothing about learning remotes. Regards, Frank. |
Silver Member Username: Davidpa
Portland,
Oregon
US
Post Number: 495 Registered: Nov-05
| Posted on Saturday, November 17, 2007 - 04:27 pm: |
The pronto JFYI, can be a pain. I have a Mosaic, and it carried more codes for my system, and was a bit easier to have it learn the functions it did not know. I tried the Pronto on two seperate occasions, the last being last xmas (my wife bought it for me) cant remember model number, but it was a 2000.00 remote at the time, color screen etc. and even through their website there were certain functions, as well as my Rotel DVD player that it would not accomodate. Maybe things have changed by now, but for me, it was just easier to stick with the Mosaic. |
Bronze Member Username: Magfan
Post Number: 51 Registered: Oct-07
| Posted on Thursday, November 22, 2007 - 12:47 pm: |
Can you get some help from the Logitech/Harmony folks? |
