Home > Message Board > Home Audio > Subwoofers > Sub phase? help
Author Thread: Sub phase? help
Username: Mikerod007
I have a Klipsch SW12 II. I also have Rti4's. I want high to go to Rti4's. I set the crossover on the sub so lows go to sub. However, what does the phase knob do(Switchable 0 or 180 degrees)? How should I set it?
Relevant Product Info
Here is the link to specs
http://www.klipsch.com/products/discontinued/details/sw-12-ii.aspx#specification s
Username: Jan_b_vigne
Dallas, TX
Post Number: 11581
You set the phase switch to which ever position sounds best over the broadest area. Since phase is relative you will only be correct at certain frequencies and incorrect at others. Experiment and read your owner's manual.
Username: Arande2
Rattle your ...
Missouri
Post Number: 2640
BUUUUUUUUUURP.
Oh, excuse me. And no, this is not spam. I had to burp. Excuse me again for burping.
Post:
Username: Need to Register?
Password: Forgot Password?
Action:
Home > Message Board > Home Audio > Subwoofers > Sub phase? help [ « Previous ] [ Next » ]
