Thread: Hooking up a computer to a stereo. Help! |
Silver Member Username: Wattsssup
Barrie,
ON
Post Number: 107 Registered: Aug-06
| Posted on Friday, October 19, 2007 - 08:06 pm: |
First off, I know "Amps" is not really the topic here, but I wasn't sure where to post this question, and I want some traffic. I'm in the midst of shopping for a new laptop, and I've had the idea for a little while now that at some point I'd like to use it with my stereo. That said, I want to make sure I get what I will eventually need (i.e. soundcard? USB DAC? etc). I'm prepared to look at external DACs when the time comes. I've been doing some research over the net, but I'm more confused now than I was before. I read some about the Squeezebox...is this the way I should go? Do I need to any hardware in particular? Is this quality any good? Any suggestions to get me headed in the right directions? |
New member Username: Shanbia
Post Number: 2 Registered: Oct-07
| Posted on Friday, October 19, 2007 - 10:30 pm: |
Marc, i have done this with my pc and also my laptops on board sound card and works a treat.I purchased a 3.5 rca plug that converts to two RCA plugs and run that straight into my Line In sockets ( or any input socket e.g cd,video), in my amp and this then is powered by a power amp. The whole system then sounds up my house. Got 4 set of speakers in all. this is a inexpensive and easy alternative without blowing a budget. |
Barrie,
ON
Post Number: 108 Registered: Aug-06
| Posted on Saturday, October 20, 2007 - 10:38 am: |
Thanks George. I'm probably looking at "blowing a budget". I expect that I'll be buying a DAC and using it with my PC. I'm simply at a point now, that I don't know if/how the soundcard comes into play with that scenario. Are there certain features I should be looking for from the soundcard for best results? Is there anything else I need to consider from the PC? The Dell guys don't know and couldn't help me. I'm not sure if this is the best way to go either (i.e. are there better options to achieving this goal?). As always, any more help would be appreciated. |
Silver Member Username: Dmitchell
Ottawa,
Ontario
Post Number: 362 Registered: Feb-07
| Posted on Saturday, October 20, 2007 - 01:35 pm: |
I use this DAC with my PC based system: http://www.audiomagus.com/component/page,shop.product_details/category_id,25/fly page,shop.flypage_modern/product_id,31/option,com_virtuemart/Itemid,27/ To me it made a noticeable improvement in SQ. No need to blow the budget... |
Barrie,
ON
Post Number: 112 Registered: Aug-06
| Posted on Sunday, October 21, 2007 - 08:55 am: |
Thanks David. So I guess my only concern then is choosing the right DAC? |
Ottawa,
Ontario
Post Number: 363 Registered: Feb-07
| Posted on Sunday, October 21, 2007 - 09:06 am: |
The nice thing about using a DAC like this (it connects via USB) is that it bypasses the soundcard in your PC. This alone is probably enough to give you a boost in sound quality. I've read that having an outboard DAC is preferable because it's not affected by interference within the computer case (fan, etc..). |
Barrie,
ON
Post Number: 113 Registered: Aug-06
| Posted on Sunday, October 21, 2007 - 07:55 pm: |
Alright then, no need to worry about the soundcard. I'll get a new laptop, and shop DACs in the following months. Thanks. |
