Thread: Ipod Nano wont connect with Itunes, just charge. |
New member Username: Supp_brittany
Post Number: 1 Registered: Oct-07
| Posted on Tuesday, October 09, 2007 - 07:31 pm: |
I just recently found an ipod nano and when I tried to upload my music onto it, it will only charge, it wont connect with itunes. I've tried the 5 R's or whatever, everything Apple suggests to try, but nothing works. Anyone know what to do?} |
Platinum Member Username: Project6
Post Number: 14118 Registered: Dec-03
| Posted on Monday, December 31, 2007 - 03:15 pm: |
Try using a different USB cable. When you say you "found an iPod Nano"...did you mean it was not yours and you just found it somewhere? If you did, there is probably a good reason why it was lost or thrown out. |
