Home > Message Board > Home Audio > Subwoofers > Archive through February 27, 2008 > What size subwoofer for my open floor...
Author Thread: What size subwoofer for my open floorplan (repost for botched title)
Username: Stangjason
Post Number: 85
I don't know what size subwoofer to get because our listening area is part of our kitchen and dining area which makes it a very large room but on the otherhand I believe our den area is only a medium listening area if you consider the seating area.
Username: Stefanom
Vienna, VA
United States
Post Number: 1046
What is the total cubic footage of the room?
How far are you from the sitting area?
What kind of SPLs are you trying to achieve?
Post Number: 86
Well the sitting location is about 14 feet from the receiver and center channel etc. The room is about 16X16 ft but behind the sitting locations it's a lot more because of the kitchen and dining room probably more like 25X25ft.
btw after posting this I decided to break the budget and bought a VTF-1 from HSU...I hope it was a good decision.
Username: Stefanom
Vienna, VA
United States
Post Number: 1049
I suspect you'll be pleased with what you get.
Username: Nuck
Post Number: 8840
Stang, that sub is quite good at music, suffers a bit if you whack the volume.
If you are normal, that sub is quite good.
The price don't kill ya neither, good buy.
Username: Arande2
Rattle your ...
Missouri
Post Number: 2621
"If you are normal, that sub is quite good."
That's a big IF.
Post Number: 87
I'm probably not normal but I think I'll like the sub anyways...normals overrated anyway and boring.
Home > Message Board > Home Audio > Subwoofers > Archive through February 27, 2008 > What size subwoofer for my open floor... [ « Previous ] [ Next » ]
