Home > Message Board > Home Audio > Subwoofers > Archive through February 27, 2008 > HSU STF-2 vs Velodyne DPS-10 vs other...
Author Thread: HSU STF-2 vs Velodyne DPS-10 vs other subs
Username: Stangjason
Post Number: 83
I can get any of the first two subs for less than $400 and I was wondering if there was a better deal out there I'm missing? Oh and which one is better of course?
Thanks,
Jason
My system: Polk CSR (center), Polk R300 (fronts), Polk R150 (rears)
Username: Jan_b_vigne
Dallas, TX
Post Number: 11456
I'd go with the Hsu. There has been a recent comparison of several subwoofers in the Hsu price range. Sorry, I can't remember where, but you can probably find it by way of a search engine.
Username: Stefanom
Vienna, VA
United States
Post Number: 1044
Depending on how frugal you want to be, and how big of an eyesore you want, this might be a decent match for you as well...
http://www.outlawaudio.com/products/lfmcompact.html
Note: Outlaw subs are designed by Dr. Hsu, and Outlaw has a very respectable reputation of its own.
Username: Kevincorr
Fairbanks, Alaska
Usa
Post Number: 277
I am very impressed with my HsU. After several years it required a repair which was done locally. The repairman, a musician was blown away by it.
Username: Nuck
Post Number: 8893
Unless the Dps 10 is miles better than my Dps12, I wouldn't spec it.
It always sounds slow.
It integrates with an open room pretty well, with corner reinforcement, but hangs on too long with just about any music. B-
Home > Message Board > Home Audio > Subwoofers > Archive through February 27, 2008 > HSU STF-2 vs Velodyne DPS-10 vs other... [ « Previous ] [ Next » ]
