Home > Message Board > Home Audio > DVD-Audio & SACD > SACD Vs DVD-A
Author Thread: SACD Vs DVD-A
Username: Wiredcon
Phoenix, AZ
U.S.A.
When I see the same album on different formats such as DVD-A and SACD. How can one tell which is better from another?
Is there a website where I can see the reviews of those albums that were released on both formats?
I was looking at Diana Krall's LOVE SCENES DVDA, and then I realized that the same album is also available on SACD.
Any advice would be greatly appreciated.
Thanks,
Ryan
Username: John_a
London
U.K.
Post Number: 4758
Ryan,
For reviews, try
http://www.highfidelityreview.com/
Username: Akachuckg
I believe which sounds better is more player dependant than anything else. My Onkyo SP800 for example, just does DVD-A better.
Username: Idrivearocket
Post Number: 77
I think they both sound great. Who cares which is better. Our alternative these days is MP3...
Username: Audioquery
Since i need to have analog connections to enjoy dvd-a/sacd, do i also need to connect say 5 pair cables(less the sub)from receiver to player to enjoy multichannel sacd or i need to only have the right n left analog and just have a 5.1 speaker set-up?
Username: Artk
Albany, Oregon
Post Number: 6735
2 pair and a spare (probably means 3 pair which = a spare).
In other words you need one cable per channel + sub.
so i really need 5 analog cables plus the sub cable.thanks for the info art..
Username: Samarch
DVD-A has a stronger output than SACD. All depends on what set up you have such as AMP & player. DVD-A can be played on any DVD player and SACD can only play on supported players. I have both! The way I see it is if you can get your SACD's to play in 5.1 Muli-channel you'll pull a great sound, then you should be in your eliment!
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Home Audio > DVD-Audio & SACD > SACD Vs DVD-A [ « Previous ] [ Next » ]
