Home > Message Board > Home Audio > Amps > Archive through January 10, 2008 > NAD 7100 preamp/tuner/amp Fading problem
Author Thread: NAD 7100 preamp/tuner/amp Fading problem
Username: Babahu
Suddenly the balance changes, or perhaps one channel gets lower. Sometimes some popply or scratchy noise but mostly the image moves left or right... occasionally, then it settles down for a while, then again.
I assume some volume control circuit is messing up? Any fix? Any suggestions?
Username: Nuck
Post Number: 8777
Hugh, does this happen only with the tuner? Do you have another source to try, a cdp perhaps?
Have you tried another input to the preamp, or switched interconnects around?
Have you serviced or replaced speaker leads in recent memory?
Username: Babahu
It happens with tape or cd input. I suspect the preamp section. Speaker leads are old but I wiggled them to no effect. It seems more temperature, corrosion, or capacitors in some kind of volume/balance circuit. Tapping the circuit board and wiggling gives no output noises.
Switched interconnects to no effect.
The manual mentions "feedback controlled volume control" or some such. Perhaps this circuit is failing and muting the output. Know anything about this feature?
Username: Nuck
Post Number: 8778
Sorry, Hugh, but no.
I know recaps are not very expensive though.
Home > Message Board > Home Audio > Amps > Archive through January 10, 2008 > NAD 7100 preamp/tuner/amp Fading problem [ « Previous ] [ Next » ]
