Thread: Another use for my T-Amp |
Silver Member Username: Dmitchell
Ottawa,
Ontario
Post Number: 314 Registered: Feb-07
| Posted on Wednesday, September 26, 2007 - 09:09 am: |
I was a little hesitant to try this since I didn't think my Trends TA-10.1 wouldn't go loud enough, but last night I used it to power my outdoor speakers on my deck. Not only did it have more than enough volume, it sounded GOOD. Better than the 50 watt NAD I was using before. |
Gold Member Username: Nuck
Post Number: 8762 Registered: Dec-04
| Posted on Wednesday, September 26, 2007 - 03:48 pm: |
The little wonders never cease to amaze! |
Ottawa,
Ontario
Post Number: 322 Registered: Feb-07
| Posted on Thursday, September 27, 2007 - 10:22 am: |
I have the T-Amp turned up maybe a quarter turn and it's plenty loud. It also sounds really, really good, even through some extraordinarily unremarkable Polk outdoor speakers. |
Post Number: 8779 Registered: Dec-04
| Posted on Thursday, September 27, 2007 - 05:12 pm: |
Is that a Trends or other uprated amp, Dave? |
Gold Member Username: Exerciseguy
Brooklyn,
NY
United States
Post Number: 1339 Registered: Oct-04
| Posted on Thursday, September 27, 2007 - 08:32 pm: |
Yes, the Trends TA-10.1 is that good. Best $100 I've spent in quite a while (I bought it used). David, what speakers are you usually using with the Trends? |
Ottawa,
Ontario
Post Number: 323 Registered: Feb-07
| Posted on Thursday, September 27, 2007 - 09:06 pm: |
You're right Christopher, It's the TA-10.1. I tried it before awhile with my Tannoys and I found it didn't go loud enough (this was in my home gym - big room, concrete floor...). Strangely enough, outside, it sounds amazing. I'm hearing sh!t in familiar music that I haven't heard before. |
