Home > Message Board > Home Audio > Cassette > Cassete player keeps switching tape f...
Author Thread: Cassete player keeps switching tape froom side a to side be and b to a over and over again pleese help
Username: Brandon_norwood
Hartselle, Al
Us
my dad has a 95 ford ranger. stock radio cassette player. well when i put in a cassette, it keeps goin from side a to side b and b to a over and over again. ittle play on side a for like a couple seconds and then swap. then repeats tha process. if anyone can help id really appreciate it
Username: Wattsssup
Barrie, ON
Post Number: 73
Rip it out the dash board and throw it accross the street. See if that helps.
Username: Dscrobe
Reading, PA
Post Number: 80
Brandon, I had that happen to me one time in my car cassette deck. Try cleaning the heads and use a different tape. Then check to see if it happens again.
Username: Manualrebello
Kalyan, Maharashtra
India
Post Number: 7
Brandon check charles posting on the same forum for 12/27/08...i hope it helps you...if not then trouble me...take care
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Home Audio > Cassette > Cassete player keeps switching tape f... [ « Previous ] [ Next » ]
