Thread: Outlaw 990 & 970 |
Bronze Member Username: Avnovice
AL
Post Number: 19 Registered: Mar-07
| Posted on Wednesday, September 12, 2007 - 09:11 pm: |
The Outlaw site states that the 990 "Digitally Re-Masters PCM to 192 /24" How is that different from "192 kHz 24-bit DAC's for all channels" The 970 does not state anything about the digital remastering comment, only the DAC's. Thanks in advance. |
Platinum Member Username: Jan_b_vigne
Dallas,
TX
Post Number: 11259 Registered: May-04
| Posted on Wednesday, September 12, 2007 - 11:13 pm: |
. I'd have to read the literature once again to be certain, but stating you use "192 kHz 24-bit DAC's for all channels" doesn't imply upsampling on any source material It merely implies your DAC's have more headroom than required to process a 16 bit signal. |
AL
Post Number: 20 Registered: Mar-07
| Posted on Thursday, September 13, 2007 - 11:21 pm: |
Thanks Jan. A bit off topic, but in one of your prior posts you recommended to someone that they should also listen to a MOSFET preamp if they were interested in tubes... Other than B&K ( and maybe Parasound? - not sure), will you list a few brands for me with MOSFET preamps and surround processors? |
Dallas,
TX
Post Number: 11267 Registered: May-04
| Posted on Friday, September 14, 2007 - 12:37 pm: |
. Sorry, I don't have that information. You'll have to do some research unless others can provide brand names. |
Gold Member Username: Stu_pitt
Irvington,
New York
Post Number: 2088 Registered: May-05
| Posted on Friday, September 14, 2007 - 02:51 pm: |
Adcom may do MOSFET preamps. I know they used MOSFET in their power amps. |
AL
Post Number: 21 Registered: Mar-07
| Posted on Friday, September 14, 2007 - 08:31 pm: |
Thanks, I'll keep searching. Just want to hear one or two. I've found a few integrated amps w/ MOSFET designs....nothing other than B&K for surround processors. |
Gold Member Username: Nuck
Post Number: 8639 Registered: Dec-04
| Posted on Friday, September 14, 2007 - 10:52 pm: |
av, just wondering...what is the attraction of the fet array that interests you so? |
AL
Post Number: 22 Registered: Mar-07
| Posted on Saturday, September 15, 2007 - 06:39 pm: |
Just curious about the sound. Thinking about the upgrade path and I want to hear what I can along the way. I don't really know anything special about the FETs of any variety. I've read some good oohs and ahhs about the Creek Integrated with MOSFETs... probably has more to do with Mr. Creek than Mr. FET. My general idea for the upgrade path is for the two channel suff; get a new/better source, either Rotel 1072 combined with Rotel pre or Rega with a nice integrated. Surround processor interests me for later - just curious if anyone makes a reasonably priced one with MOSFETs. I'm not even gonna consider the B&K. Too much for the surround cost. I want to put the emphasis on the two channel...will likely get the outlaw 970 (990 is too big) someday. |
Post Number: 8657 Registered: Dec-04
| Posted on Saturday, September 15, 2007 - 10:14 pm: |
Keep poking around, av. The 2 channel stuff can be very rewarding, unless movies are your thing. I use my stereo to great rewards for films. |
