Home > Message Board > Home Audio > Receivers > Archives - 2004 > Archive through May 25, 2004 > Phono preamp for HK AVR130
Author Thread: Phono preamp for HK AVR130
Username: Drumsuck
St. john's, Newfoundland
i need a phono preamp for my HK 130. I'm currently using a crappy Intertan 9V battery powered preamp from Radioshack.
I'd like something that is of a little better quality and warmer tone than what I have.
The turntable in question is a Gemini XL-500II.
what about the models on www.phonopreamps.com?
Username: Landroval
Post Number: 174
http://www.nadelectronics.com/hifi_amplifiers/pp2_framset.htm
Username: Hawk
Highlands Ranch, CO
Post Number: 607
Brad:
Check out these phono pre-amps from The Needle Doctor:
http://www.needledoctor.com/s.nl/c.ACCT106601/sc.2/category.401/.f;jsessionid=ac112b801f43b7a4c4ed5cf242a98d0eef494a16b310.qQvJq2PEmlnva30N-BbQmkL z-ATzr6Lzn6rzqwTxpQOUc30KaNDNo6XKq6zInRmTbgbNo6XK-kDvrA4Ka3aIqQvJq2PEmlnva30N-Bb QmkLz-ATzr6Lzn6rzqwTxpQOxahmMbh8MbNaLa2b48QvJpkixn6jAmljGr5XDqQLvpAe_
I particularly like the BT926 as a budget solution for $70. Also, if you are willing to spend more, look at the Sumiko ProJect Box for $119. It is superb.
Good luck!
Username: Drumsuck
Thanks for the help/advice.
I have returned my AVR 130 for the more powerful and practical HK 3380. I have no need for a surround receiver and so when Future Shop got the HK 3380 in, I decided it was a smarter move and more cost effective.
The phono preamp built into it is vastly better than what I was using. In a few years I'll probably upgrade.
Now I have to wait until Tuesday for my Gemini 'table to show up. Then to pick a cartridge...
Home > Message Board > Home Audio > Receivers > Archives - 2004 > Archive through May 25, 2004 > Phono preamp for HK AVR130 [ « Previous ] [ Next » ]
