Thread: Which speakers for Marantz gear? |
New member Username: Floridahog
Florida
Post Number: 2 Registered: May-04
| Posted on Tuesday, May 18, 2004 - 12:42 pm: |
Just ordered a new Marantz receiver 7400 and would like suggestions for speakers. My budget is somewhat limited since we have also ordered a 60" LCD and new DVD player etc. What would yall suggest for a budget of under 1K? I also presently have a set of Vandersteen Audio Model 1 floorspeakers that could fit into the equation. These have been used with an older Rotel 2 channel receiver. Anyone willing to chime in would be a real help here. Thanks |
Florida
Post Number: 3 Registered: May-04
| Posted on Tuesday, May 18, 2004 - 12:55 pm: |
I just realized I left a few things out. I am looking to do a surround setup and the mix of video/music would be just about 50/50. The overall room size is approx 18" W X 32" L although the seating area is half of that. Thanks |
New member Username: Fletcher
New York,
New York
Post Number: 6 Registered: May-04
| Posted on Thursday, May 20, 2004 - 11:40 pm: |
Hi, I'm actually looking for the same, speaker packages paired with Marantz 7300. I have short listed a few, and thought it might help. If you can audition them, please let me know what you think. Monitor Audio B4 system Acoustic Energy Evo 3b Infinity Primus System Mordaunt Short 902 System (They are all around the same price point)
ChrisAG Unregistered guest |
| Posted on Friday, May 21, 2004 - 09:57 pm: |
I have the Mordaunt-Short 906 with my SR6200, it's a great match. |
| Posted on Saturday, June 12, 2004 - 12:38 pm: |
I have the Klipsch Reference series with my Marantz SR8300 and it sounds amazing... |
New member Username: Mad320
Upstate NY,
NY
Post Number: 7 Registered: Jun-04
| Posted on Sunday, June 13, 2004 - 03:12 am: |
Have Marantz SR6400 With 3yr old Paradigm Legend speakers that have the Subwoofer built right into the speaker. They have excellent sound for both music and home theater. I am looking to upgrade and it will most certainly be to the Paradigm monitor 90P speaker, also with the built in sub. I have one question for you though? Do you realize the only difference between the 6400 and the 7400 is the 7400 upgrades all video to component, which is great but if you have a high def tv and DVD player you are using component cables any way. The only thing left is the VCR which is hardly used any more. The other difference is the 7400 lets you control two different rooms. Ask your self if the $200.00 more you are paying for the 7400 is worth it. either way you will be happy with the marantz receiver. My OPINION and just that is, try out a pair of Paradigm Speakers. Heck I will have a pair for sale soon for anyone interested. Let me know what you decide on in This forum topic and how they sound. Good Luck |
