Home > Message Board > Home Audio > DAC and Transports > Trends UD-10 USB Audio Converter
Author Thread: Trends UD-10 USB Audio Converter
Username: Dmitchell
Ottawa, Ontario
Post Number: 222
Anyone tried one of these yet?
In my secondary system in my gym I have a Yamaha receiver driving 4 speakers (pair of Tannoys and a pair of PSBs) and a subwoofer. The source is my PC connected via a soundcard to the Yamaha. It actually sounds not too bad, but I'm sure it could be MUCH better.
Worth this be a worthy upgrade from using the soundcard onboard the PC?
Relevant Product Info
Username: Jan_b_vigne
Dallas, TX
Post Number: 11133
How much do you require in your gym? The Trends is not that expensive. If you just can't think of another way to spend the money, then, why not?
Username: Dmitchell
Ottawa, Ontario
Post Number: 225
How much of what do I require? Volume? ... it's plenty loud. I'd just like it to sound loud and good! LOL
Username: Davidhitokcom
Hong Kong, Kowloon
Hong Kong
Post Number: 9
The price is US$149 for Trends UD-10 and US$20 for the Trends Charge Kit. If you are planning to use PC for better audio
experience than going for individual Hi-fi music system (better buy
speakers for PC than buy audio systems with surround system features). Trends Audio UD-10 + Trends TA-10 Amp will be the good choice
Post:
Username: Need to Register?
Password: Forgot Password?
Action:
Home > Message Board > Home Audio > DAC and Transports > Trends UD-10 USB Audio Converter [ « Previous ] [ Next » ]
