Home > Message Board > Home Audio > Integrated Amps > Nad vs Rotel
Author Thread: Nad vs Rotel
Username: Eduardox
For those how have been able to compare the NAD C320 BEE aand C521 BEE vs the Rotel RA03 and the RCD02
Which do you like better? Why?
Thanks
Relevant Product Info
Username: Hoanghai2k
Melbourne, VIC
Australia
Post Number: 27
depent on ur taste of music, type of speaker, kind of room .... and so on....
that all i know man. Goodluck
Username: Nickelbut10
Post Number: 268
ohhhhhhhh thats a hard choice. Their both in the same level with each other in terms of performance. But both sound completely different. You will like whichever one you think sounds better to you. It really depends on the speakers and such you will be using as well.
Username: Milpai
Post Number: 11
If this helps you to make a decision:
NAD - warm, laid back sound
ROTEL - cool, front row seating sound
Me and my friend own a Nikon D200 (same choice). But when it came to integrated - I went with NAD and he chose the Rotel. You need to audition both and then decide what you like. Also depends on the "type" of music you listen to. Make an extra effort to listen to both before you invest. Good Luck.
Post:
Username: Need to Register?
Password: Forgot Password?
Action:
Home > Message Board > Home Audio > Integrated Amps > Nad vs Rotel [ « Previous ] [ Next » ]
