Home > Message Board > Home Audio > Subwoofers > Archive through February 27, 2008 > Sub for Quad11L
Author Thread: Sub for Quad11L
Username: Kevincorr
Fairbanks, Alaska
Usa
Post Number: 170
I love the Quads but they have less bass than my Rogers L3/5A. Still I put the HsU power sub woofer VTF2 back with the Rogers because it is HUGE, but fits in my "vinyl" room.
So the wifes living room has the Quads alone. Looking at a sub to go with them. Size and look being a factor or I would simply get another HsU. Looking at the VTF1 in maple. http://www.hsuresearch.com/products/vtf-1.html
OK, I promise to post some pics today.
Almost as big as the ugly old VTF2 but looks much better in wood.
We don't need or want much bass, as this is not home theater, just 2 channel, and it is an apt.
So I started researching small compact subs but have not learned much except a few recommended brand names. Veladyne has been mentioned here and gets good reviews. Has compact models. I see on AudiogoN Monitor Audio 360. There are a lot of subs there and on ebay. The popularity of Home Theater seems to have given speaker makers a big boost.
For example, on ebay some cheapies: Psb Alpha Sub Zero i;
B&W ASW 300 Subwoofer Maple; Monitor Audio RADIUS 360;
Not a big investment so I would be willing to give any of them a try.
Ideas?
Username: Kevincorr
Fairbanks, Alaska
Usa
Post Number: 171
Just looked at ebay again and see the B&W and Monitor have only 4 hrs left. Oh well, plenty passing by.
The truth is I am very tempted to stick with what I know, HsU.
Username: Kevincorr
Fairbanks, Alaska
Usa
Post Number: 172
Does front speaker style transmit more into the room and less to other rooms than downfacing speaker? I would guess it is the same because it is vibration from the box, right?
I put my HsU up on 4" blue foam then 4" patio block. I think it helps keep sound in the room but am not sure.
Username: Nuck
Post Number: 8331
KC, when the sub is integrated properly, the configuration really does not matter.
The firing position of the sub might make proper integration of the unit easier, but that is room dependant.
Your requirements, the rolloff, and rollin of the thing will decide for your ears.
With either Beethoven or Roll over Beethoven.
Username: Kevincorr
Fairbanks, Alaska
Usa
Post Number: 173
"...Beethoven or Roll over Beethoven..." I like that. Right now I am playing Sultans of Swing LOUD on the Sultans of Swing. The mid base on the Quad is nice at that level but disappears on the quieter music.
Any thoughts on these cheap units, say Monitor http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem%26%26item%3D230160190803&ssPageNam e=STRK:MEWA:IT&ih=013
Giving up quality to get a smaller size?
Username: Kevincorr
Fairbanks, Alaska
Usa
Post Number: 174
Ebay is wild. I had never looked at it before a month ago. That Monitor 360 sub was won by $10 with 6 seconds to go!
But that same thing happened to me already several times.
I missed a bunch of deals on AudiogoN too. Most recently a pair of Quad12L went as soon as they went online. I watched my nephew sell a Toyota Pickup in Seattle on Craigslist in 4 minutes! I could not believe it.
Username: Kevincorr
Fairbanks, Alaska
Usa
Post Number: 175
"...Right now I am playing Sultans of Swing LOUD on the Sultans of Swing..."
Jeez! That was w/o alcohol too. Now playing Money for Nothin" LOUD on the Quad11L.
Username: Artk
Albany, Oregon
Post Number: 5240
Last I heard Quad makes a great sub....
Username: Kevincorr
Fairbanks, Alaska
Usa
Post Number: 177
I am sure they are good. There is a beauty on sale now in bird's eye maple but it is even bigger than my old Hsu.
Here is one like I have now: http://cls.audiogon.com/cgi-bin/cls.pl?homesubw&1190924340
I see Quad Lite model is somewhat smaller but is not exactly small at 75 pounds.
Username: Artk
Albany, Oregon
Post Number: 5241
I had an Era that was quite small and weighed 70 lbs. Small and dense.
Username: Stu_pitt
Irvington, New York
Post Number: 2068
I don't know your budget nor do I know the specs and sizes, but a few names to look into are -
ERA
REL
Totem
Martin Logan
I haven't heard Quad subs. Linn makes a very small and decor friendly sub - Komponent sub. I haven't heard it nor know how much it costs, but you may want to research it. If you've got some cash and space, Naim makes a killer sub. Its about $3K though.
Username: Nuck
Post Number: 8338
For 3k I might consider the JLaudio 13" unit.
Username: Kevincorr
Fairbanks, Alaska
Usa
Post Number: 186
Thanks for the ideas, guys. I guess I was checking if my first idea was good.I am pretty sure I will go for the Hsu mentioned at the top. Can't go wrong at the price!
The expensive ones don't compute for me because for that kind of money I would buy some speakers that don't need a sub.
Username: Kevincorr
Fairbanks, Alaska
Usa
Post Number: 192
I made the order: http://www.audioadvisor.com/prodinfo.asp?number=VESP800R&variation=BLK; ordered from Audiogon: http://cls.audiogon.com/cgi-bin/cls.pl?homesubw&1191275075
It is small and black to match the monitors. That will keep her happy.
Username: Nuck
Post Number: 8354
That one looks promising, Kevin.
Username: Artk
Albany, Oregon
Post Number: 5254
That's a very good litle sub Kevin. One of the higher end Velo's.
Username: Nuck
Post Number: 8355
Art, you and Frank have commented on the lower Velo's being not so hot. Does this constitute a better quality of sub for a tighter(and higher volume) unit for a stereo?
Would you consider this Velo a step closer to a rel or such?
More music?
Username: Kevincorr
Fairbanks, Alaska
Usa
Post Number: 200
I will let you know when it gets here! Truthfully, if it were for any other room than the living room I would have gone with another one, maybe the Hsu in wood or the Quad. I have no conflict with the boss on this stuff, but the Velo does match the glossy piano black monitors that she was so pleased with. I know, looks should not be the prime concern nor is it in "my" room. The Velo was a good price and is small and looks like a set.
It does bring up a question of hifi journalism. I have no real reason to trust HiFi Choice mag but admit that when I saw the "Product of the Year Award" in the July 07 issue and the sub on AudiogoN. I have been wanting to post the question of magazines here. In any case, it did influence me but I usually do hold critics esp music with a grain of salt.
Username: Artk
Albany, Oregon
Post Number: 5259
It's not like REL or ERA but different altogether. Very tight high power subs...good choice for music (I know I said that already).
Username: Kevincorr
Fairbanks, Alaska
Usa
Post Number: 202
I have not heard the REL or ERA. It is not easy to shop in the boon docks! Just have to give it a try.
Username: Artk
Albany, Oregon
Post Number: 5262
I think you'll be pleased....
Username: Kevincorr
Fairbanks, Alaska
Usa
Post Number: 206
I am getting nervous. Big flurry of emails while we cemented the deal Fri Aug 17 when I did the paypal order.
Now Mon eve Aug 20 and still no response from seller. I have requested a shipping date. He is observing silence.
When should I get really worried??
Username: Kevincorr
Fairbanks, Alaska
Usa
Post Number: 208
Yes, finally got the shipping notice Aug 21.
Username: Nuck
Post Number: 8385
Warm up the dogsled, Kevin.
Airport pickup.
Home > Message Board > Home Audio > Subwoofers > Archive through February 27, 2008 > Sub for Quad11L [ « Previous ] [ Next » ]
