Thread: Bookshelf Speaker recommendations |
New member Username: Silvannone
Post Number: 1 Registered: Jan-05
| Posted on Saturday, August 11, 2007 - 08:38 pm: |
Hello Everyone, I'm in the market for a set of bookshelf speakers for a sitting room/office that's about 20 x 12 feet. I'm looking to spend not more than $400 or so. I have a Pioneer VSX-D603S A/V Receiver, a Sony CDP-C545 CD Player, a Sony TC-K615S Cassette Deck, and a really old Technics SL-J3 Direct Drive Turntable. I would appreciate any suggestions. Thanks, Lisa |
Relevant Product Info
Gold Member Username: Exerciseguy
Brooklyn,
NY
United States
Post Number: 1227 Registered: Oct-04
| Posted on Saturday, August 11, 2007 - 09:31 pm: |
Consider these: AV123 X-LS http://www.av123.com/products_product.php?section=speakers&product=82.1 Monitor Audio Silver S1 http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem%26item%3D320144851945 Infinity Beta 20 http://cgi.ebay.com/INFINITY-BETA-20-CHERRY-NEW-PAIR-199-AUTHORIZED-SELLER_W0QQi temZ130142445980QQihZ003QQcategoryZ14991QQcmdZViewItem Whafedale Diamond 9.2 http://www.tsto.com/cgi-bin/tsto.storefront/EN/product/2615 There are many others, but these would be on my short list. |
Bronze Member Username: Wattsssup
Barrie,
ON
Post Number: 21 Registered: Aug-06
| Posted on Saturday, August 11, 2007 - 09:38 pm: |
Boston Acoustics also have a number of bookshelf speakers that are within your price range and are sold just about everywhere. http://www.bostonacoustics.com/home_product.aspx?collection_id=1&category_id=4 |
Platinum Member Username: Jan_b_vigne
Dallas,
TX
Post Number: 11073 Registered: May-04
| Posted on Saturday, August 11, 2007 - 10:40 pm: |
. These will do everything you need in that situation; http://www.circuitcity.com/ssm/Sony-Bookshelf-Speakers-SS-B1000/sem/rpsm/context /99000229/oid/179949/catOid/-16882/rpem/ccd/productDetail.do |
Gold Member Username: Artk
Albany,
Oregon
Post Number: 5197 Registered: Feb-05
| Posted on Saturday, August 11, 2007 - 11:22 pm: |
http://www.goodsound.com/features/2007_03_01.htm |
Brooklyn,
NY
United States
Post Number: 1228 Registered: Oct-04
| Posted on Sunday, August 12, 2007 - 07:51 am: |
Jan, have you been drinking? |
Dallas,
TX
Post Number: 11076 Registered: May-04
| Posted on Sunday, August 12, 2007 - 11:47 am: |
. No. Is that an offer? |
Gold Member Username: Nuck
Post Number: 8274 Registered: Dec-04
| Posted on Sunday, August 12, 2007 - 12:16 pm: |
I have, Here have one. Lisa, is this enough to get you started? I might suggest you look for Usher speakers as well. |
Silver Member Username: Rysa3
Houston, Texas
Post Number: 191 Registered: Nov-06
| Posted on Sunday, August 12, 2007 - 12:24 pm: |
Mysuggestions are as follows; 1. Get your turntable cleaned and possibly a new stylus and cartridge if needed. This can be done for about 45 dollars or less depending on where you take it. 2. Lots of bookshelf options. I truely like the Ascend CBM 170s. Another good choice are PSB Alphas. I have both of these. I'd try and get the older Ascends used if I could. But thats an opinion. AS opposed to the newer SEs , which are already being swapped out ( I am not sure the new tweeter thing worked out so well) 3. I don't like the sound of av123.com bookshelfs at all. Their strength is in subwoofers really. |
Albany,
Oregon
Post Number: 5209 Registered: Feb-05
| Posted on Sunday, August 12, 2007 - 12:29 pm: |
The little Ushers are very good indeed! |
Post Number: 8277 Registered: Dec-04
| Posted on Sunday, August 12, 2007 - 12:40 pm: |
That's from your tip a while back, Art. That was a very happy customer indeed. |
Post Number: 8278 Registered: Dec-04
| Posted on Sunday, August 12, 2007 - 12:44 pm: |
Marc, I still have Alpha's in the family. Are yours the first series run, Like labelled as just 'the amazing Alpha'? Very capable, if dated a bit. I built a pair of light 2x4 stands for them, and they were very lively. Very good speakers, for cheap. |
Brooklyn,
NY
United States
Post Number: 1229 Registered: Oct-04
| Posted on Sunday, August 12, 2007 - 03:27 pm: |
Anytime your in NYC Jan, I'm buying. At $399, those Monitor Audio Silver S1's are an exceptional value, however, for $250 (delivered) these Infinity Beta 20 are the best bargain going, IMHO. Yes, I know I own a pair, and we all want to like what we own, but consider that I absolutely LOVED my Mission M32i, and the Beta 20, by a slight margin, bested them. |
Dallas,
TX
Post Number: 11080 Registered: May-04
| Posted on Sunday, August 12, 2007 - 04:10 pm: |
. " ... I absolutely LOVED my Mission M32i, and the Beta 20, by a slight margin, bested them." In what way? |
Brooklyn,
NY
United States
Post Number: 1230 Registered: Oct-04
| Posted on Sunday, August 12, 2007 - 04:32 pm: |
The Beta 20 & M32i have very similar spacial qualities, but the Beta 20 have noticeably better low-end. Bass was more enveloping, deeper, and just seemed more effortless. I had previously considered the M32i's low-end to be one of it's strong points. |
Dallas,
TX
Post Number: 11081 Registered: May-04
| Posted on Sunday, August 12, 2007 - 05:07 pm: |
. Do you think that's a desirable quality in an office/sitting room system? Driven by a Pioneer receiver? |
Brooklyn,
NY
United States
Post Number: 1231 Registered: Oct-04
| Posted on Sunday, August 12, 2007 - 06:58 pm: |
Point taken. I lost track of the original post, focusing instead on the $400 budget, my bad. With that in mind, I will however offer-up these suggestions to keep in mind, in addition to Jan's suggestion, when shopping around: Insignia NS-B2111 @ $72 Mission M70 @ $69 Pioneer S-HF21-LR @ $49 Polk Audio R150 @ $49 |
Houston,
TX
Post Number: 2 Registered: Jan-05
| Posted on Sunday, August 12, 2007 - 09:30 pm: |
Hi Guys, Thanks for all the information. I think I'm going to go with the Ascend CBM 170 as a first choice and the Infinity Beta 20 as a second choice. I was using $400 as a ball park figure for my lowly and antiquated Pioneer receiver. I'm using Athena speakers with a Harman Kardon Receiver in the A/V room. Thanks, Lisa |
Albany,
Oregon
Post Number: 5227 Registered: Feb-05
| Posted on Sunday, August 12, 2007 - 09:45 pm: |
Enjoy! |
Silver Member Username: Kevincorr
Fairbanks,
Alaska
Usa
Post Number: 148 Registered: Jul-07
| Posted on Monday, August 13, 2007 - 12:15 am: |
I notice PSB alpha on Arts' link there. I came very close to buying these: http://www.stereophile.com/standloudspeakers/580/ but went bigger. |
Houston, Texas
Post Number: 192 Registered: Nov-06
| Posted on Monday, August 13, 2007 - 08:03 pm: |
Nuck- I bought the PSB Alphas in 1995 or 1996. They really didn't get a lot of use back then, and I wasn't as tuned into higher end audio quality as I am now. But I really enjoy listening to them these days, and do so almost everyday. AS far as Usher monitors, I have heard good things about the Usher s-520 bookshelfs ( i think those were the ones). Despite visiting the Usher rooms for the past three years at CES, I dont ever recall auditioning them. I'll be on the lookout in 2008 for them to be sure. Ascend came out with a new bookshelf just recently that is apparently causing quite the sell off. I have never understood pre-buying a speaker that hasnt been released and that you can't audition, and I never will. Anyway, there should be a heck of a lot of Ascend CBM170s for cheap now, creating quite the value. |
Post Number: 8297 Registered: Dec-04
| Posted on Tuesday, August 14, 2007 - 06:57 am: |
Marc, good to see you again. My story is the same with the Alphas. Used a receiver, then a better receiver, then amp the all new stereo. The little Alphas have played well. Our son uses them now. |
Gold Member Username: Frank_abela
Berkshire
UK
Post Number: 2306 Registered: Sep-04
| Posted on Tuesday, August 14, 2007 - 07:03 am: |
Not exactly sure about pricing, although I know they're int he ballpark. You could go for B&W's new DM686. Very good speaker indeed. Regards, Frank. |
New member Username: Eduardox
Post Number: 7 Registered: Aug-07
| Posted on Thursday, August 16, 2007 - 09:43 pm: |
Frank. What was improved in the 686 vs the 601? Thanks |
Fairbanks,
Alaska
Usa
Post Number: 185 Registered: Jul-07
| Posted on Friday, August 17, 2007 - 06:05 am: |
I am glad you asked because I was unaware of the new line in spite of having just auditioned B&W locally. I listened to the 601 and 602 and could live with either one. They had not received the new line. I better go down and see if they have a sale!!!! |
Silver Member Username: Gavdawg
Upstate,
New York
Post Number: 816 Registered: Nov-06
| Posted on Friday, August 17, 2007 - 10:43 am: |
The speaker that Ascend came out with is called the Sierra. It is supposedly far and away better than anything else they have ever released. |
Houston, Texas
Post Number: 196 Registered: Nov-06
| Posted on Monday, August 20, 2007 - 11:00 pm: |
Hey Gavin--ya I know that. But have you listened to it? Thats my point... |
Upstate,
New York
Post Number: 827 Registered: Nov-06
| Posted on Tuesday, August 21, 2007 - 08:37 am: |
No I haven't... but I did not care for the CBM 170. IMHO, it sounded boxy. |
Berkshire
UK
Post Number: 2312 Registered: Sep-04
| Posted on Tuesday, August 21, 2007 - 11:32 am: |
Eduardo, The 686 replaces the DM600, not the 601. the new 68x range is quite different to the old 600 series. However, as in the 600 series, the entry level 686 is a very enjoyable performer indeed. It's quite a different design to the 600, being deeper and narrower with new drive units and crossover. I haven't got my head around the whole range yet so I can't offer much more than that. Regards, Frank. |
Houston, Texas
Post Number: 197 Registered: Nov-06
| Posted on Tuesday, August 21, 2007 - 10:42 pm: |
It certainly looks boxy...mine are on right now -- cant even localize the sound actually... Blindfolds anyone? |
