Thread: Need help solving pre-echo when playing vinyl record |
New member Username: Bfl6h6m
Stafford,
Va
Post Number: 1 Registered: Aug-07
| Posted on Wednesday, August 08, 2007 - 12:52 pm: |
Playing (and trying to record) some of my vinyl albums,I'm hearing the song at a low volume for a split second before the song begins. This is creating a kind of (what I call) 'pre-echo' that continues thru the whole album. I'm going to change to a new cartridge hoping the problem is a worn-out needle,but I'm wondering if anyone else has experienced this trouble and resolved it? |
Platinum Member Username: Jan_b_vigne
Dallas,
TX
Post Number: 11037 Registered: May-04
| Posted on Wednesday, August 08, 2007 - 01:40 pm: |
. The problem is not due to a worn stylus. The problem is this is the way vinyl behaves when the manufacturer doesn't give a crap. |
Stafford,
Va
Post Number: 2 Registered: Aug-07
| Posted on Wednesday, August 08, 2007 - 02:47 pm: |
The record manufacturer or the turntable manufacturer? (And you're right...changing the stylus didn't help.) |
Stafford,
Va
Post Number: 3 Registered: Aug-07
| Posted on Wednesday, August 08, 2007 - 02:49 pm: |
Oops...I re-read your message and saw the vinyl reference. |
