Thread: CD player problem |
New member Username: Kerouacknew
Trout creek,
Ontario
Post Number: 1 Registered: Aug-07
| Posted on Wednesday, August 08, 2007 - 09:17 am: |
My son turned off my cd player while it was playing. Now it will not play later tracks on any cds. It will play the first 8 or 9 songs but will not read any tracks past that. I am assuming the laser is somehow out of alignment. is there anyway to fix this myself? thanks Shawn My cd player is an older sony cd carosel. |
Gold Member Username: Frank_abela
Berkshire
UK
Post Number: 2297 Registered: Sep-04
| Posted on Wednesday, August 08, 2007 - 10:24 am: |
Your son's action should not have caused such a dramatic effect. When powering the unit back on, it should have just reset itself. Alignment of the laser is very rigidly controlled. The chances are either that this was an unlucky coincidence (but blame him anyway - it's good for the soul ). There are no user serviceable parts in machines like this. Sony may try to fix it for you (good luck - they, along with many majors, are not renowned for fixing their older units). Either that or find a qualified engineer to do the job. Regards, Frank. |
Platinum Member Username: Jan_b_vigne
Dallas,
TX
Post Number: 11030 Registered: May-04
| Posted on Wednesday, August 08, 2007 - 10:50 am: |
. Do you have any idea whether there might be a disc stuck in the machine? |
Trout creek,
Ontario
Post Number: 2 Registered: Aug-07
| Posted on Wednesday, August 08, 2007 - 02:18 pm: |
I do not believe that there is a disc stuck inside but i would have to check to be sure. It appears that this is only affecting my burned Cds as i tried a couple purchased ones and they play fine. It was working fine with burned ones just last week. Maybe the laser has gotten dirty perhaps? |
Trout creek,
Ontario
Post Number: 3 Registered: Aug-07
| Posted on Wednesday, August 08, 2007 - 11:29 am: |
i am very confused by this. I have been burning a lot of cds lately and now most of them will not play past track 8. They work fine in my computer so have been burned correctly. Have tried them in two different players now with the same results. They play fine until near the end and then appear to not be able to read the disc and reset themselves. Would appreciate any suggestions as i am stumped by it. I believe they were working fine( i think) as i have played them before. Shawn |
Gold Member Username: Nuck
Post Number: 8216 Registered: Dec-04
| Posted on Wednesday, August 08, 2007 - 01:02 pm: |
Shawn, please clarify. Purchased cd's will play OK. Some cdr's will play OK? And the same cdr's will play OK in the car? The cdr's crapout halfway through on the Sony, but the same one will play through in the car? Burners have a finite lifespan, and fail at the end of the disc first. |
Post Number: 8217 Registered: Dec-04
| Posted on Wednesday, August 08, 2007 - 01:03 pm: |
But I like Frank's answer, too |
Dallas,
TX
Post Number: 11035 Registered: May-04
| Posted on Wednesday, August 08, 2007 - 01:37 pm: |
. I think you're just discovering one of the epiphanous mysteries of CD-R's. I have plenty that play fine in one player and not another or play fine through the first tracks only to skip and distort at the end. It's God's way of telling you, "Thou shalt not rip off music." Sony is God, you know. |
Post Number: 8220 Registered: Dec-04
| Posted on Wednesday, August 08, 2007 - 07:14 pm: |
Clapton'll have 'em in court! Shawn, new cdp's are cheap.And way better. Look up Oppo players. |
Trout creek,
Ontario
Post Number: 4 Registered: Aug-07
| Posted on Wednesday, August 08, 2007 - 10:52 pm: |
Through trial and error i have discovered that the burner in my emac appears to be producing this problem. I tried burning at a slower speed 2X with the same problem. I hooked up my old ezquest burner and it burned fine. Wish i would have caught this sooner as i now have around 10 cds which only work past 9 in my computer. |
Berkshire
UK
Post Number: 2303 Registered: Sep-04
| Posted on Friday, August 10, 2007 - 06:28 am: |
Good catch Shawn. I'd have actually pointed the finger at the discs. So many are now being manufactured which are almost not to standard (did I say almost? My mistake). We get customers having bought serious kit (you know - £1800 DVD players) which can't play their copies of discs and generally it turns out to be the discs themselves which are just out of spec. Regards, Frank. |
Dallas,
TX
Post Number: 11051 Registered: May-04
| Posted on Friday, August 10, 2007 - 09:53 am: |
. How do you determine the discs are out of spec? |
New member Username: 94_eclipse
Circleville,
Ohio
America
| Posted on Sunday, August 19, 2007 - 02:08 pm: |
i got a 95 eclipse and i took the batt. out of it and now i need the code the numbers on the radio are......MR158590 serial#49199130 im not sure what one is the vin number so here are the numbers i got 3430026 and c24657cwyd..and if u could also tell me how 2 put the code in.....i drive 30 min 2 work every day and i have no radio and it is drivin me crazy thanks it would help ALOT!! |
Circleville,
Ohio
America
| Posted on Sunday, August 19, 2007 - 03:56 pm: |
i have a 94 eclipse and i need the radio code MR158590 SERAIL#49199130 IM NOT SUR WHAT ONE IS THE VIN NUMBER SO HERE R THE NUMBER I GOT 3430026 AND C24657CWYD} |
Post Number: 8360 Registered: Dec-04
| Posted on Sunday, August 19, 2007 - 04:04 pm: |
go to cars, cody |
