Home > Message Board > Home Audio > CD Players > Archive through January 30, 2008 > CD player for KAV 400 and B&W 805
Author Thread: CD player for KAV 400 and B&W 805
Username: Eduardox
What would be your recommendation of CD player for Krell KAV400 and Nautilus 805 (old version) in the 1000 to 1500 range?
Thanks a lot
Eduardo
Username: Nuck
Post Number: 8189
The usual recommendation for a grand. BUT...
A Banchmark DAC1 can be had with mods for a good price, then it comes down to a transport. Way under a grand. Plus cables.
Username: Jan_b_vigne
Dallas, TX
Post Number: 11025
Whajja got now? And what are the options available to you, eduardo.
Username: Eduardox
I have a NAd 521 bee
I can buy any available in the USA, Cary, Rega, Rotel, Nad, Arcam, whet else? As loong as it is in the $1500 limit
Prefer one unit vs transport and DAC separates
Thanks
Dallas, TX
Post Number: 11034
So, you don't intend to audition any players or speak with a dealer? We get to tell you what to buy?
Username: Nuck
Post Number: 8215
Oh Boy! Buy my used one then. Just kidding, Ed.
What does your present player(and/or system) not do right?
Timing? Rythm? OOmph?
Username: Sukhoi30
New Zealand
Post Number: 131
I second Nuck, Dac 1 (with a USB input).
Someone reliable once told be that he could not tell the difference between a FMJ 36 and a DAC 1 with a cheap DVD player as a transport. He had some very good associated gear.
I guess with a good transport and a DAC one you could get a way lot more and are future proof just in case you want to use your comp for music few years down the line.
Sorry to suggest this once again - but worth considering.
I would also look at Quad CDP2, excellent and time tested.
and the new Cambridge 840c might be slightly higher that your budget but can be used as a DAC as well in the future.
Cheers
Username: Eduardox
I know my B&W and Kreel can sound better, better detail and better image than with the Nad C521 BEE that is why I want to upgarde
Username: Hoanghai2k
Melbourne, VIC
Australia
Post Number: 26
i reckon Marantz SA8260... should be low price for now
Username: Unbridled_id
Chicago
Usa
Post Number: 197
How about that cambridge 840 c ?
Username: Kevincorr
Fairbanks, Alaska
Usa
Post Number: 193
No Nuck, I get your used one! Man they go fast on AudiogoN. So does Rotel 1072. One just went the 1st few hours that it went on there. That Saturn is hanging on at $1700 though.
Username: Kevincorr
Fairbanks, Alaska
Usa
Post Number: 194
Nuck, that was a hint.
Username: Nuck
Post Number: 8341
I ain't biting.
Username: Mike3
Wiley, Tx
Post Number: 642
At least you would have something to take a picture of...
Username: Nuck
Post Number: 8357
Eduardo, the Rega Apollo is unbeatable at the price point in the US.
In Canada, it is priced a bit higher, but still nobody does it better.
Check pricing there.
I have many source, and the Rega is the best purchase(so far), as long as you play only redbook cd's.
If you play hdcd, then that is a different matter.
Altogether.
Home > Message Board > Home Audio > CD Players > Archive through January 30, 2008 > CD player for KAV 400 and B&W 805 [ « Previous ] [ Next » ]
