Home > Message Board > Home Audio > Speakers > Archive through October 13, 2007 > Peel paint from the walls
Author Thread: Peel paint from the walls
Username: Rocks911
I own a Parasound preamp and a Sunfire 200 wpc amp. Simple question: What moderately priced speaker can reliably produce outrageous sound levels?
I recently purchased Polk's RTi12 speakers and am not entirely satisfied (luckily I only paid $800, otherwise I'd be quite upset). I played Soundgardens Badmotorfinger at +4 db and the speakers shut down within five minutes. What speaker can handle very dynamic music at very loud volumes without submitting.
Relevant Product Info
Username: Jan_b_vigne
Dallas, TX
Post Number: 10996
The speakers didn't shut down, the amplifier went into protection. Big difference.
How much do you want to spend?
Username: Rocks911
Not so,
The rest of my speakers were working just fine. I had them dialed down but they didn't shut down the mains did. You think that's the Sunfire?
Dallas, TX
Post Number: 10999
I don't know. You've confused me with facts I didn't have before me a few moments ago. What do you mean, "The rest of my speakers were working just fine. I had them dialed down but they didn't shut down the mains did." How many speakers do you ahve connected to the amp and how are they connected? Are there switches and volume controls involved here?
Username: Rocks911
I have a 5.1 system all connected to a Sunfire 200 wpc amp through a Parasound preamp.
I had the surround set to the "party" mode which delivers stereo through the mains and rear channels and a stereo mix through the center channel. I can independently adjust each of the 5.1 configuration, the mains, the rears, the center, and the sub. I had the rear and center speakers turned down relative to the mains. When I turn the music up they all get louder, but the mains are much louder relative to the rest of the speakers.
Anywho, I adjusted the volume to +4 db and within five minutes the mains shut down while the rest of the speakers were fine.
Also to answer your question about price, lets just say about $800 for mains. This is not necessarily something that I'm considering, my wife would kill me, but I'm wondering what speakers out there can handle seriously dynamic very loud music.
I read a lot of reviews that talk about for example Beethovens sixth concerto and the warm bassoon movement punctuated by timpani...etc.etc. and thats really not for me, I like loud grinding wall shaking sound, not all the time mind you but occasionally I enjoy it. I've never read a review that critiqued a speaker for its ability to play for example Soundgarden at outrageous levels for sustained amounts of time. Given a decent set-up, and I feel like I have a decent set-up with the Sunfire and Parasound combo, what speaker can perform what I am asking?
Dallas, TX
Post Number: 11000
Are the speakers still not working? A 5.1 system must have more than two channels of amplification. So, I assume you've just been running the Sunfire on the front speakers or the Sunfire is a multichannel amplifier. Either way, speakers don't normally stop working all together. Amplifiers do.
If you have no sound from the speakers, the amp is probably at fault even though the other channels of amplification are still working. If you have no sound at all from the speakers, check the operation of the speakers to determine where the problem lies. Disconnect the speaker cables to the Polks at the amplifier and use a 1.5 volt battery to check the speakers. Touch the "+" & "-" legs of your speaker cable to the terminals of the battery and listen for a slight pop as the drivers move in or out. If you hear this sound and see the driver's move and you still have no sound at all from the amplfiier, the chances are you've fried the amplifier unless it has fused lines for each channel.
Otherwise, you need to look for speakers with a high sensitivity (or efficiency) rating. This is stated as "(90)db @ 1 meter @ 1 watt or 2.83 volts" on the spec sheet. The higher the decibel rating of the speaker at that 1 watt input the louder the speakers play for any amount of amplifier power. A 90dB speaker plays as if it had twice as much amplifier driving it as a 87dB speaker can. A 93dB speaker plays louder for the same amount of power output as a 90dB speaker.
Lines such as Klipsch, JBL and Cerwin Vega are typically high sensitivity speakers. High sensitivity often means the speaker is not as smooth in its frequency response as a less efficient speaker, so listen and compare. But volume comes from that dB rating. You can also look at pro audio sound reinforcement speakers for volume. Actively powered speakers are quite high in overall volume potential and can be had for not much money. Check with your local sound reinforcement shops for more information on this sort of speaker.
Username: Albertaguy7
Medicine Hat, Alberta
Post Number: 8
I had a spy around in the site for your amp and I would say that Jan is right about the amp oing into protection mode. All thye amps seem to have seperate amp sections for each channel. Yours having 5 - 200 watt amps. You may have overdriven the two for the main speakers. Just a lil bit of info for you...just because you still have room to turn the volume knob doesn't mean the amp can handle the power you want to put out.
Back when I was a kid we used to but Cerwin Vega or JBL's if we wanted loud noise. I say noise because they didn't sound too good but you could hear it a few miles away if you cranked it up.
Turning it up past the amps handling ability can also cause the amp to spike, and then you may kiss it and the speakers goodbye. Warrenty will not cover overdriving of either the speakers or the amp. And, they will know you did it.
Username: Kano
BC
Post Number: 1217
I have the Polk Rti as well and I think they present a difficult load. While still being 8 Ohms they eat up a lot of power at high spls - I've had my 200W/C amp flashing reds into Rti 8s - wasn't even THAT loud, just a bass heavy recording.
Find a speaker with a higher sensitivity with less impedence swings if you're having trouble with the Rti12s... or get even more of an amp.
Username: Nuck
Post Number: 8180
DR, the Cerwin Vega line will pound till your ears bleed, especially the classic 15 series.
And they are cheap!
Like 112-114db in the room loud.
Stinking loud.
Huh?What?Is that the phone?
Dallas, TX
Post Number: 11006
No, it's your ears still ringing from those CV's you had five years ago.
Username: Exerciseguy
Brooklyn, NY
United States
Post Number: 1197
I'll one up you Nuck, try the CLS-215 http://www.overstock.com/Electronics/Cerwin-Vega-CLS215-15-inch-3-way-Tower-Spea kers/2118904/product.html .
They should come with a free copy of "ASL for Dummies".
Username: Stu_pitt
Irvington, New York
Post Number: 2024
I've said it many times...
Cerwin Vega - The official speaker of the Canadian Ballet
And for very good reason.
Dallas, TX
Post Number: 11009
OW! I hurt myself hitting the floor.
Username: Skeeterhead
Post Number: 76
I don't believe it. Jan is actually referring to a spec sheet.
Username: Nuck
Post Number: 8195
Stryvn said he has a pair of CV, what the hell are they? in the basement with 2 15" woofers.
What are they, Stryvn?
Username: Nuck
Post Number: 8196
Let's put our hands together for Crystal!
Username: Stryvn
Post Number: 374
lol...I love a good Ballet!
I gotta get those things back in working order so the kid can resume the paint removal.
And no eating the paint chips, Wiley!
Dallas, TX
Post Number: 11029
Too late. The damage has been done.
Username: My_rantz
Australia
Post Number: 1462
"I don't believe it. Jan is actually referring to a spec sheet."
Jan, flagellation time again.
Username: Gavdawg
Upstate, New York
Post Number: 782
M.R.
I think "flatulation" might be more appropriate in that sentence :-P
Username: Nuck
Post Number: 8208
On a more ominous note, I think 'infatuation' creeps in there as well.
Username: Rocks911
Thanks for the replies.
Apparently it is the amp, I've never experienced the amp shutting down before.
I have a pair of CV's in the attic I bought about eighteen years ago that need replacement speakers as they are paper and dry-rotted. As a young man thats all I used, CV that is, and now I understand why nothing else cranked quite like them, they seem to be the gold standard for ear bleeding sound levels.
Thanks again, and I love the comments, especially the "Canadian Ballet" comment.
Dallas, TX
Post Number: 11033
Yes, I will refer to a spec sheet on ocassion. This was one of them. If the discussion had progressed I would have mentioned enclosure volume as a relevant factor in SPL production. Fortunately, this thread doesn't have to got hat far.
It seemed of little value to take this thread down another course when the basic question was how to peel paint. That I gave a very simplified answer to that particular question, rather than confuse the issue by stating the irrelevance of specs, seemed the appropriate action. That in no way changes my opinion regarding the value of specifications. Just expediency, nothing else at play here. All , 88, 92 or 96dB speakers do not play at the same level. Specs are ultimately irrelevant other than HxWxD plus weight. As is, DR understands higher numbers in the sensitivity column represent high SPL's. That was the original question of the thread. Why anyone would wish to hijack yet another thread on this forum to serve their own ends is beyond me.
My job is over here. Yiho, Silver, away!
Post Number: 77
Oh, Oh, Janny done got upset. Not our fault if he can't make up his mind.
Username: Gavdawg
Upstate, New York
Post Number: 786
Brooklyn, NY
United States
Post Number: 1209
...JERKOFF ALERT!...JERKOFF ALERT!...
This is a coordinated monthly test of the broadcast stations in your area. Equipment that can quickly warn you of JERKOFFS is being tested. If this had been an actual JERKOFF such as Dennis Michael Wiley, official messages would have followed the alert tone. This concludes this test of the JERKOFF Alert System.
Username: Gavdawg
Upstate, New York
Post Number: 787
Username: Nuck
Post Number: 8219
hehehe
Dallas, TX
Post Number: 11038
"You wanna go where people know,
people are all the same,
You wanna go where everybody knows
you're a troll."
Post Number: 78
Very nice, intelligent responses. Of course, I use the word "intelligent" very loosely when applied to Gavin, Molloy, Nuck and Vigne.
Username: Gavdawg
Upstate, New York
Post Number: 799
loosely applied? like a hotdog down a hallway?
Username: Gavdawg
Upstate, New York
Post Number: 800
I do realize this is not a winning battle.
Dallas, TX
Post Number: 11042
When wiley suggests he has a clue what is "intelligent', it's time to fold the tents and declare victory.
Have a weinie, wiley.
Brooklyn, NY
United States
Post Number: 1213
It's absolutely a battle that can't be won, but that shouldn't preclude us from pouncing on this jackass.
Post Number: 84
Oh, Oh, it must be all idiots day. Here they come one after the other.
Username: Gavdawg
Upstate, New York
Post Number: 801
I take it that was in reference to yourself?
Brooklyn, NY
United States
Post Number: 1214
Just who started this?
You poke your empty head into this thread, add nothing, and start slinging insults. What do you expect?
My advise is to switch names & start fresh, and make beleive this didn't happen.
Username: Gavdawg
Upstate, New York
Post Number: 802
Chris, that is all Wiley ever does, and ever did before they were previously banned. He (or she) will pop into threads, and the above will occur, usually aimed at Jan. Lately, it has also been aimed at Nuck, Frank, and sometimes myself.
Username: Gavdawg
Upstate, New York
Post Number: 803
It is to the point that he has become the messageboard cabin boy so to speak, because of how his crass and awful treatment of members has gotten out of hand. Most members who he has attacked don't think twice about jumping down his throat at any given instance.
Username: Stryvn
Post Number: 391
I feel slighted.
Wiley, you're ugly.
Post Number: 86
Man, I love free press. Was it Andy Warhol who said everybody gets 15 minutes of fame?
Post Number: 87
Gavin, I think the use of the word "they" would exclude reference to myself. Man, what a smart guy you are.
Username: Nuck
Post Number: 8231
Yes it was.
But it was Nuck who invited you to takeasuckofmyass.
And troll Stryvn, he trades advice here too and hasn't been included in your inanities.
Post Number: 89
Nice, Nuck. Doing what you do best, I see.
Username: Stryvn
Post Number: 393
Sheesh. I get the sharp stick in the eye from Nuck.
When all I wanted was some lovin' from the Wiley Coyote.
ACME seperates and IC's. Does ACME publish specs, I wonder?
Username: Nuck
Post Number: 8233
Stryvn, just wanted Wiley to pay attention to you. No stick intended.
Post Number: 92
Turncoats are like that, Stryvn.
Username: Mike3
Wiley, Tx
Post Number: 616
DMW must be on welfare and traded his stamps for wine so he couldn't get his meds.
Poor little puppy all shriveled in a corner paranoid of everything and everybody. Don't worry, the next check is in the mail and you can contribute something positive for a week until, well you know it is a regular cycle with you.
Or maybe as Gavin suggests, you're just off your cycle, as usual.
Username: Nuck
Post Number: 8267
We got 3 buddies here, and Dale Wiley is chirping.
takeasuckofmyass
Wiley.
Did you miss that before?
Username: Mekongdelta69
Grew up in Brooklyn an...
Post Number: 52
Trolls are on EVERY one of the hundreds of thousands of forums/boards on the Net, covering every conceivable topic known to mankind (ask your kids/grandkids how many trolls -- and far more dangerous -- predators, who hang out on teen/20s sites. I'd personally strangle those pervs if I ever caught one.)
Anyway, I don't care if you collect belly-button lint for a hobby -- there just HAS to be SOMEBODY who insists on sticking his nose in and acting like a 9 year old, petulant, spoiled brat. He doesn't get enough attention IRL, has low to no self-esteem and probably has a low-rent job, where he's an absolute nobody and couldn't buy a date with a call girl.
One example I can think of here was that idiot (Eric Gracka) in my thread where I was asking for CD upgrade opinions when I was brand new here. He claimed he was some kind of 'engineer' and then proceeded to keep posting the same msg. multiple times because he "couldn't get the hang of this sight(sic)." Another freakin' genius. He got banned, but his posts remain (unfortunately).
I used to argue with these Prozac-deprived people a long time ago until I realized I was wasting my time and energy. Once in a blue moon, when I'm bored and feel like sticking somebody in the eye, I'll still do it, but the best way to get rid of trolls is to ignore them. I'll grant you it's less fun than cursing them out or making fun of them, but it works almost every time. Sooner or later, like ignoring a kid having a temper tantrum, they get tired of whining because they don't get the attention they crave -- and just wither away back to doing what they do best -- bagging groceries at the A&P.
These miscreants pretty much live to get a rise out of people because the rest of their (real) lives are pretty pathetic, and when they do, it gives them a 'charge' and it makes them feel like they've served up some 'payback.' The targets of their insults are just stand-ins for their wives or girlfriends or bosses or the guy that beat them up in the bar last night. The Net just gives them further anonymity, so they get all stupid and brave. [You should see some of the trolls on the military sites I belong to. Not only did they take Hamburger Hill all by themselves -- they ate Hamburger Hill for lunch! We pretty much debunk guys like that in about 10 seconds...]
This is what I do now when I run across trolls:
Username: Buzzy
This is such an awesome forum about speakers.
Dallas, TX
Post Number: 11077
