Thread: Denon AVR3805 I need setup help please |
New member Username: Pantera28
Post Number: 1 Registered: Jun-07
| Posted on Friday, June 01, 2007 - 10:00 pm: |
I just installed a new AVR3805 and cannot get the remote speakers (Zone2) to operate using Satellite, Cd or any input source. I have run through the manual atleast 6 times and checked everything. Can someone help please? I know I'm missing something simple and stupid. Thank you, Kirk |
Post Number: 2 Registered: Jun-07
| Posted on Friday, June 01, 2007 - 10:09 pm: |
Just went through set up gain...nothing! |
Gold Member Username: Nuck
Post Number: 7469 Registered: Dec-04
| Posted on Friday, June 01, 2007 - 10:48 pm: |
Kirk, did you have a load to the 2nd zone on the setup? The receiver expects a load. |
Post Number: 3 Registered: Jun-07
| Posted on Friday, June 01, 2007 - 11:56 pm: |
I used to have an AVR 2800 which has a second set of speaker connections. We used these to drive our deck speakers and basement speakers through a Monster swtch box. I connected the AVR 3805 with the speaker connections for the Zone 2 to the Monster box. Wouldn't the speakers be the load? What exactly do you mean by a load? Thanks for the reply I appreciate any help I can get. |
Post Number: 4 Registered: Jun-07
| Posted on Friday, June 01, 2007 - 11:58 pm: |
What or how do I actually turn Zone 2 on? I did exaclty as the manual says and tried inputting different sources. Is there a chance the internal second amp is responding? The unit was new. |
Silver Member Username: Mike3
Wiley,
Tx
Post Number: 411 Registered: May-06
| Posted on Saturday, June 02, 2007 - 03:15 am: |
Are you using analog RCA inputs from your source to Zone 2? Optical or digital do not work for zone 2 in my Denon, only RCA. |
Post Number: 5 Registered: Jun-07
| Posted on Saturday, June 02, 2007 - 02:50 pm: |
My DVD is RCA inputs and it doesn't work. I'll try the CD with RCA as it is Optical now. Thanks Michael. It seems like a great unit. Just having a little learning curve! |
