Home > Message Board > Home Audio > Subwoofers > Archive through June 24, 2007 > Need new sub
Author Thread: Need new sub
Username: Sound_quest
Post Number: 17
i need a new sub something that going to be loud but have good quailty to
Username: Stefanom
Vienna, VA
United States
Post Number: 623
Well fortunately for you, there are lots of subwoofers out there of decent quality of all shapes, sizes, price, etc. What did you have in mind for any of these attributes? Room dimensions? Usage?
Post Number: 18
well i got plenty of room 400-600 price range 12's or 15's
Username: Jan_b_vigne
Dallas, TX
Post Number: 10511
12's or 15's? How many drivers do you think you need?
Username: Artk
Albany, Oregon
Post Number: 4863
Is this for car or home? If for a car I suggest you try the car audio section.
Username: Starbucks
Post Number: 23
Hei friend,
Need suggestion from you guys
I need a subwoofer for my current setup. NAD 542 CDP, NAD C370 and Quad 11L speaker.
Looking for subwoofer approximatel USD200. Any good suggestion...brand and model. Many thanks.
Username: Stefanom
Vienna, VA
United States
Post Number: 712
From the gossip I here, the best in that price class are probably the Bic H-100 (who knew they made more than razors!) and the Onix X-Sub. The X-Sub would likely be your best bet in terms of overall quality however.
How big of a room are you looking to fill? What will you be playing?
Home > Message Board > Home Audio > Subwoofers > Archive through June 24, 2007 > Need new sub [ « Previous ] [ Next » ]
