Thread: HK Zone 2 IR Extender |
Bronze Member Username: Markstanco
Texas
Post Number: 27 Registered: Jul-05
| Posted on Wednesday, May 16, 2007 - 04:04 pm: |
I am looking in to adding an extender to my HK AVR7300 for Zone II operation on my patio. Are there options available other than the HE1000-A? I would certainly like to only have a receiver "eye" outside if possible. Thanks! |
Platinum Member Username: Jan_b_vigne
Dallas,
TX
Post Number: 10432 Registered: May-04
| Posted on Wednesday, May 16, 2007 - 06:06 pm: |
. Use someone else's transmitter/receiver for the second zone. What other kind of "options" are you looking for? |
Bronze Member Username: Topher
Post Number: 20 Registered: Dec-03
| Posted on Tuesday, May 29, 2007 - 12:56 pm: |
I was using the zone 2 feature of my 325 with a Recoton IR repeater & didn't have too many problems. It seemed to be acceptable to interference, though. I also tried Jensen & they worked, too, but if I plugged it into the ir jack on the rear of the HK, the 325 would cycle through surround modes, I think. The Recoton didn't do this. I gave up on the zone 2 thing as it was too much trouble & went with my old Sherwood receiver & a modded Xbox upstairs. An IR repeater, not an extender, would have saved a lot of aggravation. My gear downstairs is on the back wall, so I needed to use an IR repeater. I went with a Xantech kit. You mount the eye were you want it, run cat 5 to your gear, connect it to a connecting block, plug IR transmitters into the block & affix them to your equipment (or plug a mini-plug to mini-plug cable into the IR input on the HK). I'd recommend this method. It's bullet-proof & can control up to 8 pieces of equipment. The IR extender thing can be real frustrating. Check ebay. Xantech (or Speakercraft, or Niles, or...) can be found pretty cheap, if you have the time to wait. |
