Thread: NAD C740 problem- no sound through speakers anymore |
New member Username: Misterdee
Post Number: 2 Registered: May-07
| Posted on Monday, May 14, 2007 - 01:03 pm: |
Can no longer hear music through loudspeakers, unless I crank volume to maximum; even then, I can barely hear anything. Headphones work fine, can play tunes as loud as I want. I had attempted to connect my imac computer, via RCA cable, to the NAD receiver. Foolishly, I started plugging into each jack, to see which sounded the best. I also plugged into the 'pre-out' and 'main in' jacks, without turning off receiver. (I later found my instruction manual, which stated I should always turn off receiver before plugging in/ pulling out cable from these 2 jacks). Not sure if I screwed things up because: (A) I plugged cable into these jacks, or (B) I didn't turn off receiver when connecting/ disconnecting cable from these jacks Any idea what might be wrong (besides the fact that I should never have messed with the pre-out/ main in jacks)? The glass fuse inside looks fine. |
Post Number: 3 Registered: May-07
| Posted on Monday, May 14, 2007 - 05:11 pm: |
Problem solved. Jumpers between pre-out and main in were replaced incorrectly. Infinity's singing again... |
