Thread: Mcintosh mx 120 |
New member Username: Shiro
Post Number: 8 Registered: Apr-07
| Posted on Saturday, May 05, 2007 - 08:10 am: |
Does anyone have the mcintosh mx120? Im close to buying the mx120 with mc 207. I know its not the best to use HDMI through most audio ,but the mcintosh i think will be good .Any comments about that? |
Gold Member Username: Nuck
Post Number: 7151 Registered: Dec-04
| Posted on Saturday, May 05, 2007 - 08:56 am: |
Sure, George, ignore the hdmi. Keep the audio and video functions purely seperate. A unit that handles video is inherently subject to trade-offs in the audio dept. Walmart sells shoes and toasters. Neither the footwear or the appliance are of a standard of quality that I would strive for, but may have to settle for. Do you want to settle? |
Post Number: 7152 Registered: Dec-04
Sorry. Do you want to settle, or must you settle? Big difference. |
Post Number: 9 Registered: Apr-07
| Posted on Saturday, May 05, 2007 - 11:49 am: |
I dont want to settle..But my Marantz plasma only has 1 HDMI . I want more HDMI inputs. I also want the best audio in my price range which is 13000 |
Post Number: 7165 Registered: Dec-04
| Posted on Saturday, May 05, 2007 - 11:54 am: |
George, if you want the best audio, keep the video on it's own. |
Post Number: 7166 Registered: Dec-04
| Posted on Saturday, May 05, 2007 - 11:55 am: |
13k or 1.3 k? |
Post Number: 10 Registered: Apr-07
| Posted on Saturday, May 05, 2007 - 12:19 pm: |
13k |
Platinum Member Username: Jan_b_vigne
Dallas,
TX
Post Number: 10366 Registered: May-04
| Posted on Saturday, May 05, 2007 - 12:27 pm: |
. "I want more HDMI inputs." Yeesh! Sounds rather petulant there, GR. $13k for more inputs? Ever heard of a switch box? So, what are the alternatives? What other products have you considered if you don't buy the McIntosh? Why the Mac? What are you coming from now? What have you been using and is this change being made strictly for more HDMI inputs? You do realize in a few years HDMI, as it is currently marketed, will be as obsolete as S-video or progressive inputs are right now; don't you? That's how this industry works. You'd be better off buying a new TV every few years. . |
Post Number: 7168 Registered: Dec-04
| Posted on Saturday, May 05, 2007 - 12:33 pm: |
George, if you dropped 13k on gear with the advice of online forums, I would drive there and slap you myself.Or bring my wife. How would you rate your relationship with your dealer? |
