Home > Message Board > Home Audio > Receivers > Archive through June 12, 2007 > 1.3 HDMI recievers
Author Thread: 1.3 HDMI recievers
Username: Josh1005
Norfolk, VA
U.S.A
Post Number: 95
what do you guys think about the new recievers do you think it is really neccisary to go and spend hundreds of dollars to replace perfectly good reciever jto upgrade from 1.1 to 1.3 HDMI or will my onkyo 804 translate HD audio good enough??
Username: Kano
BC
Post Number: 1183
http://www.avsforum.com/avs-vb/showthread.php?t=789994
Home > Message Board > Home Audio > Receivers > Archive through June 12, 2007 > 1.3 HDMI recievers [ « Previous ] [ Next » ]
