Thread: Does The H/K AVR 340 Have Enough Juice? |
New member Username: Philly_t
Post Number: 8 Registered: Jan-07
| Posted on Friday, April 20, 2007 - 01:33 pm: |
I'm planning to use an H/K AVR 340 to power 2 JBL L880s, 2 L830s and an LC2, all from the Studio Series. The AVR is rated at 55 Watts per channel @ <0.07% THD, 20Hz – 20kHz into 8 ohms with all (7) channels driven. L880s: MFR: 30Hz–40kHz, ±3dB. Sensitivity: 91dB (2.83V/m). Nominal impedance: 8 ohms. Maximum recommended amplification: 200W. Power handling: 100W continuous, 400W peak. L830s: MFR: 48 Hz - 40 kHz ± 3 dB, Sensitivity: 90 dB, Impedance: 8 Ohms Nominal, Maximum Recommended Amplifier Power: 150 Watts, Power Handling (Continuous/Peak): 75 Watts/300 Watts. LC2: MFR: 50 Hz - 40 kHz ± 3 dB, Sensitivity: 92 dB, Impedance: 8 Ohms Nominal, Maximum Recommended Amplifier Power: 150 Watts, Power Handling (Continuous/Peak): 75 Watts/300 Watts. My question: Is this a good match? Will this AVR be able to handle these JBLs? Does it have enough power to make these JBLs sing? I have also read in various places that even though the Studio Series are rated at 8 Ohms, they're actually closer to 6. Thanks in advance for your thoughts! |
Platinum Member Username: Project6
Post Number: 13802 Registered: Dec-03
| Posted on Friday, April 20, 2007 - 04:08 pm: |
"Is this a good match?" - Totally up to your ears and perception. My view...Not too thrilled, I think the pairing lacks certain clarity and detail. Works for some. "Will this AVR be able to handle these JBLs?" - Yes Have you heard them or will you have the means to hear them for yourself? You mileage may vary! |
Gold Member Username: Nuck
Post Number: 6921 Registered: Dec-04
| Posted on Friday, April 20, 2007 - 04:27 pm: |
Yes it does. |
Silver Member Username: Gamerdude
Ontario
Post Number: 493 Registered: Apr-06
The H/K will have enough juice mine(avr-245) fills a 3 bed room APT easly forget walls there no good its still loud |
Post Number: 6923 Registered: Dec-04
| Posted on Friday, April 20, 2007 - 04:34 pm: |
http://forum.ecoustics.com/bbs/messages/1/346064.html |
Platinum Member Username: Jan_b_vigne
Dallas,
TX
Post Number: 10272 Registered: May-04
| Posted on Friday, April 20, 2007 - 04:57 pm: |
. http://www.myhometheater.homestead.com/splcalculator.html |
Silver Member Username: Shane24
Post Number: 109 Registered: Mar-07
| Posted on Saturday, April 21, 2007 - 09:36 am: |
hey jan, tnks for that link, i've checked it out... |
Post Number: 110 Registered: Mar-07
| Posted on Saturday, April 21, 2007 - 09:42 am: |
match is good, and will be able to handle them and offcourse h/k recommends them for all of their jbl spks, atleast most of them as far as I know... (but, my opinion people on these forums like h/k but personally i don't like them one bit) |
Post Number: 6947 Registered: Dec-04
| Posted on Saturday, April 21, 2007 - 10:26 am: |
These JBL's are a very easy load, most receivers will run them. |
Gold Member Username: Thx_3417
Bournemouth ...
Post Number: 3710 Registered: May-05
| Posted on Saturday, April 28, 2007 - 05:52 pm: |
Why not just hook up three JBL 4675-A in the room and let me know how it sounds!
Gold Member Username: Petergalbraith
Rimouski,
Quebec
Post Number: 2022 Registered: Feb-04
| Posted on Monday, May 07, 2007 - 12:13 pm: |
Hi Andy, Those would scare off most on the forum, but since I like horns I would love to hear those! |
Silver Member Username: Alright_boy
Post Number: 220 Registered: Jan-07
| Posted on Monday, May 07, 2007 - 02:59 pm: |
Remember little hoppergrass: specs mean nothing-the gospel according to Jan. I agree with Berny's analysis. |
Ontario
Post Number: 499 Registered: Apr-06
| Posted on Monday, May 07, 2007 - 03:27 pm: |
And they are right, all amp makers rate there stuff different 150watts in yamaha gear maybe be only be 70watts in pioneer gear The heavery the amp the better the power surrply and biggger caps ect.. |
Dallas,
TX
Post Number: 10372 Registered: May-04
| Posted on Monday, May 07, 2007 - 03:47 pm: |
. Say it often enough and JBJ might eventually learn what it means. Kinda like a lab rat learns when to push the button for food. Then what will happen to JBJ? Other than he will finally go away. Naw, he's not smart enough to find the button. We're stuck with his enormous contribution to the forum. |
Dallas,
TX
Post Number: 10373 Registered: May-04
| Posted on Monday, May 07, 2007 - 03:48 pm: |
. Almost forgot ... FOJBJ. |
