Thread: Fiber optic Cable |
New member Username: Parapa05
Post Number: 3 Registered: Apr-07
| Posted on Thursday, April 19, 2007 - 05:17 pm: |
Good day, I was just wondering, I have a JVC receiver and I have connected this cable and not sound, how can I have set this up, please help |
Platinum Member Username: Jan_b_vigne
Dallas,
TX
Post Number: 10266 Registered: May-04
| Posted on Friday, April 20, 2007 - 09:03 am: |
. You should go into the set up menus for the receiver and the source unit where you will find locations to assign the output/input to the optical out/in. This should be described in your owner's manual. |
Gold Member Username: Frank_abela
Berkshire
UK
Post Number: 2076 Registered: Sep-04
| Posted on Friday, April 20, 2007 - 10:20 am: |
Eduardo, As Jan says, with many receivers, you need to tell the receiver that for example the DVD input should expect a digital input from 'Opt 1'. You usually do this from the setup menu where there is an Audio assignment menu. It should be in the manual too. Regards, Frank. |
Gold Member Username: Nuck
Post Number: 6922 Registered: Dec-04
| Posted on Friday, April 20, 2007 - 04:32 pm: |
Eduardo, this the 4th time you have posted on this issue. Consulting the manual has been stated time and again. I posted the CES connections manual for you. We brought you a fork, use it or starve. |
