Home > Message Board > Home Audio > Receivers > Archive through June 12, 2007 > Subwoofer pre out problem
Author Thread: Subwoofer pre out problem
Username: Livin_loud
F uck fuckid...
Fi Audio
Post Number: 1665
So this would be my first venture into the home audio section lol, so sorry if this is the wrong place to be asking this.
i have an str-de897 and use the sub pre out line which is connected to a klh s120eth amp. basically my problem is that in order for the amp to turn on, i must turn the volume up to a certain point on the receiver, which causes a real annoyance when i don't want it that loud. now is this my receiver not sending a hot enough signal? or could it be the amp not picking it up at low volumes?
also, i can turn it up so the amp comes on, then turn it down and get the level i want, but it turns off eventually, leaving me back at square one. thanks in advance
Username: Kano
BC
Post Number: 1180
Should be a switch on the amp for on/off/auto. Change it from auto to on.
F uck fuckid...
Fi Audio
Post Number: 1693
that did the trick. kinda lame i didn't think of that on my own... weird thing is when its in 2ch its fine, but anything else and that happens.
thanks for the help!
Home > Message Board > Home Audio > Receivers > Archive through June 12, 2007 > Subwoofer pre out problem [ « Previous ] [ Next » ]
