Thread: Av receiver spec. and speakers |
charles Unregistered guest |
| Posted on Sunday, May 16, 2004 - 11:38 am: |
Can I connect my 4 ohms speakers Fr,Srr,Ctr and active subwoofer with the av receiver which has the following specifications. AUDIO SECTION Maximum Power Main Channels 80 W + 80 W Centre Channel 80 W Rear Channels 80 W + 80 W Minimum RMS Output Power (6 ohms,1 kHz, 0.1% THD) Main Channels 60 W + 60 W Centre Channel 60 W Rear Channels 60 W + 60 W High Dynamic Power,Low-Impedance Drive Capability Yes Dynamic Power/Channel 6 ohms 75 W 4 ohms 95 W 2 ohms 105 W Input Sensitivity/Impedance Phono (MM) 2.5 mV/47 k-ohms CD 150 mV/47 k-ohms Frequency Response 10–100,000 Hz +0, -3 dB Total Harmonic Distortion (1 kHz) CD (Main Sp Out) 0.06% Signa-to-Noise Ratio (CD, 250 mV) 100 dB Tone Control Characteristics Bass Boost/Cut ±10 dB 100 Hz Treble Boost/Cut ±10 dB 20 kHz I already have the speakers and only need to buy the av receiver.
| Posted on Sunday, May 16, 2004 - 03:05 pm: |
I am a newbies and I have no idea what does this specification (in my previous post) say. ( have only a little knowledge about audio terms) Hope someone can help me! |
J. Vigne Unregistered guest |
| Posted on Monday, May 17, 2004 - 07:24 pm: |
Charles - Sounds like you can drive the 4 Ohm speakers OK. Check the responses under "Amps" at "Harman Kardon" to see if that answers any of your questions about specs. Ifnot come back and I'll try to help. |
Silver Member Username: Hawk
Highlands Ranch,
CO
Post Number: 561 Registered: Dec-03
| Posted on Tuesday, May 18, 2004 - 01:51 am: |
Charles: Look on the back panel of the receiver in question. There will be a notation near the speaker output terminals telling you what impedence levels the receiver will tolerate. Although the spec sheet suggests it can handle 4 ohm speakers, I wouldn't bet the mortgage on it--that is probably with only one channel active! However, the back panel will tell the real story and I am guessing that if you have more than two channels connected, it will insist on 8 ohm speakers all around. BTW, your receiver specs read like a Denon, and my Denon did not tolerate a 4 ohm load (can you say "shutdown"!). |
Gold Member Username: John_a
Post Number: 1107 Registered: Dec-03
| Posted on Tuesday, May 18, 2004 - 09:35 am: |
charles, It looks like it is designed to cater for 4 Ohms; the spec even gives the power output for 2 Ohms. This is something to ask the dealer; he should be willing to take responsibility for getting that right. You have every right to be confused. When a maker's spec says "Minimum RMS Output Power (6 ohms,1 kHz, 0.1% THD) Main Channels 60 W + 60 W" etc. then we are all at sea without a paddle. The minimum output power has to be zero. Ideally, you would not have to switch it off to get that. |
