Thread: What's the difference: HK AVR325 vs. AVR330 |
ChiTown Unregistered guest |
| Posted on Friday, May 14, 2004 - 10:41 pm: |
Can someone tell me the difference between the HK AVR325 and AVR330? I can't find it anywhere. Thanks, Marc |
Relevant Product Info
Silver Member Username: Geekboy
Newport,
RI
United States
Post Number: 259 Registered: Dec-03
| Posted on Saturday, May 15, 2004 - 02:58 am: |
ChiTown: the AVR330 is the newer model. Not much else is different. AVR330 has a newer look (silver), and sports only 5W more per channel in 7 channel mode. Otherwise, they're mostly identical. I notice that the component video bandwidth on the AVR-325 is 50Mhz and the AVR-330 is 30Mhz... ODD! The AVR-325 weights a little more too.
Silver Member Username: Heff
Post Number: 111 Registered: Dec-03
| Posted on Saturday, May 15, 2004 - 09:24 am: |
You can read up and visit HK's latest offerings at Harman Kardon Ping: Supershad You PM'd me asking for help on an AVR-330 but didn't leave a reply address. Also you're not set up to receive a PM, as I got the result... "Sorry, but the user you have selected does not accept private messages." Just PM me with your email or turn on PM if u want a reply. |
