Thread: AS-P4100 400 Watt 10-inch Subwoofer |
Silver Member Username: Silas92
Post Number: 143 Registered: Apr-06
| Posted on Wednesday, April 04, 2007 - 08:59 pm: |
I have found the Athena AS-P4100 400 Watt 10-inch Subwoofer for $179 is this a good deal? would it blend wit my Athena micra 6's? Any comments are much apreciated  |
Post Number: 144 Registered: Apr-06
| Posted on Thursday, April 05, 2007 - 05:45 pm: |
Any 1? |
Gold Member Username: Nuck
Post Number: 6663 Registered: Dec-04
| Posted on Thursday, April 05, 2007 - 08:09 pm: |
It should blend |
Post Number: 145 Registered: Apr-06
| Posted on Thursday, April 05, 2007 - 10:06 pm: |
Well thats a start thanx! The problem with the current 8" subwoofer that comes with the Athena's is when theres a loud part of a movie, or in music the subwoofer cannot handle it and floors out. It goes all muddy and blurry. I hope the 10" will sort out this prblem. |
Post Number: 6672 Registered: Dec-04
| Posted on Thursday, April 05, 2007 - 10:13 pm: |
Try it and find out, koop. Overdoing the sub will kill the smaller setup, though. It can only go so far. |
Post Number: 146 Registered: Apr-06
| Posted on Thursday, April 05, 2007 - 10:30 pm: |
Thanx for the information "Nuck" I think i will try it. 1 more question before i do. For approximately $70 more i can get a hsu stf1, which ive heard nothing but praise about. Whats your opinion on this? |
Post Number: 6675 Registered: Dec-04
| Posted on Friday, April 06, 2007 - 06:36 am: |
Overdoing the sub will kill the smaller setup, though. It can only go so far. When the crossover points get too far away from each other, a fairly hollow gap is created. The Hsu is a great line, but you might get that gap. But enough bass is subjective. |
Post Number: 147 Registered: Apr-06
| Posted on Friday, April 06, 2007 - 10:26 am: |
So your saying i should stick with the Athena? |
Gold Member Username: Artk
Albany,
Oregon
Post Number: 4507 Registered: Feb-05
| Posted on Friday, April 06, 2007 - 10:43 am: |
The Hsu wouldn't be overkill. In fact with an 8 inch driver and more speed than average in a budget sub, it would be my choice in your setup. But then I've told you that before. |
Post Number: 148 Registered: Apr-06
| Posted on Friday, April 06, 2007 - 11:44 am: |
Yeh i do bealive you have, im just concerned about the price, if im really gettin my moneys worth? or is it goin to be a case where the sub is better than my whole system? |
Albany,
Oregon
Post Number: 4508 Registered: Feb-05
| Posted on Friday, April 06, 2007 - 12:04 pm: |
Don'y worry it ain't a REL or JL Audio, it's just a Hsu. Good all 'round performer. |
Post Number: 149 Registered: Apr-06
| Posted on Friday, April 06, 2007 - 12:19 pm: |
Ok, as long as it has more power than my current sub im fine thnx for all the help  |
Post Number: 150 Registered: Apr-06
| Posted on Friday, April 06, 2007 - 12:28 pm: |
Velodyne VX-10 Subwoofer for $139, not bad rite? |
Post Number: 151 Registered: Apr-06
| Posted on Friday, April 06, 2007 - 08:58 pm: |
scratch that last comment: Polk PSW12 for $179 12inch'er that things huge and nothing but good reviews on Amazon.com |
Albany,
Oregon
Post Number: 4512 Registered: Feb-05
| Posted on Friday, April 06, 2007 - 09:26 pm: |
Silas...buy what you want. Geez what a pain in the rear. |
Post Number: 152 Registered: Apr-06
| Posted on Friday, April 06, 2007 - 09:36 pm: |
Calmb down art, calmb down all im askin for is a little advice, and as im tight up on money i really need to make sure im getting what i pay for! u feel me? Yes the Hsu's are good, i agree but a bit out of my price range! |
Albany,
Oregon
Post Number: 4515 Registered: Feb-05
| Posted on Friday, April 06, 2007 - 09:48 pm: |
You've been given advice...BTW the Hsu isn't the only advice you were given, earlier you and another buddy were given advice around a Dayton sub. Hey I don't care if all you want to do is call out various sub models and wait for reactions but please don't act like you're asking for advice...you're not your just noodlin' without a cause. A bunch of folks here have been kind enough to spend their time tryin' to help you and Shane and the various other new kids. Shite or get off the pot as my Daddy used to say! |
Post Number: 153 Registered: Apr-06
| Posted on Friday, April 06, 2007 - 09:58 pm: |
Forget u, and yes i am new to this, and no i dont have money, and yes i am asking for advice on trying to find "the best price to performance ratio" subwoofer out there!! so if ur fed up then leave see if i care  |
Albany,
Oregon
Post Number: 4516 Registered: Feb-05
| Posted on Saturday, April 07, 2007 - 01:36 am: |
You are not asking for advice you are finding what you think is the prettiest product then asking us to validate your choice...not happenin'.  |
