Home > Message Board > Home Audio > Receivers > Archive through June 12, 2007 > Buying a Panasonic XR55s
Author Thread: Buying a Panasonic XR55s
Username: Silas92
Post Number: 139
Hello everyone i have decided to sell my Yamaha htr5930!! Its connected to Athena micra 6's, and i will buy a panasonic xr55 instead. First of all how does the panny compare to the yamaha in sound? and how well does it blend with the athena's? If i do buy the panny its an extra 2 channels do you think i should buy 2 new front speakers or just leave it and buy a decent center?
Username: Artk
Albany, Oregon
Post Number: 4481
The Panny is the worst sounding piece of audio gear that I've had the displeasure of listening to...period.
Username: Silas92
Post Number: 141
Well i guess that explains it thanx :-)
Username: Jaw
Post Number: 97
It's all about Room Acoustics; if your wife lets you relocate the Van Goghs and Chippendales, it should sound OK...
Username: Silas92
Post Number: 142
Haha well actually im only 14, so the wife at this moment in time isn't saying much! But is it comparable to the Yamaha? is it worth the extra 2 channels? thanx
Username: Artk
Albany, Oregon
Post Number: 4485
Like we hadn't already guessed your approximate age.
Home > Message Board > Home Audio > Receivers > Archive through June 12, 2007 > Buying a Panasonic XR55s [ « Previous ] [ Next » ]
