Home > Message Board > Home Audio > Subwoofers > Archive through June 24, 2007 > Connecting sub to rega mira preouts
Author Thread: Connecting sub to rega mira preouts
Username: Mrtomasulo
St. Louis, MO
Post Number: 121
Just scored a small Boston Acoustics sub (PV400) off a co-employee who is moving for virtually nothing, and need to figure how to connect it to the preouts on my Rega Mira. The sub has a single line-in input. The preouts are RCA.
So do I basically just need some kind of Y-cable with RCA connections? Will that work? Thanks.
Username: Jan_b_vigne
Dallas, TX
Post Number: 10112
You can use a single "Y" splitter to run off one channel of the Rega. It doesn't much matter which channel you use since the majority of bass information is mixed to mono or near mono anyway. If you have high levels speaker inputs on the sub, you might want to use those instead.
St. Louis, MO
Post Number: 122
Thanks Jan.
The sub does have speaker inputs. I don't know if I can fit any more wire into the speaker inputs on the Rega, though. The 'holes' are small. :-)
Dallas, TX
Post Number: 10113
Does the subwoofer have speaker in/out?
Username: Leonski
Post Number: 60
if speaker outs=yes, don't they 'daisy chain'?
St. Louis, MO
Post Number: 123
The sub has speaker level ins and line line level in.
St. Louis, MO
Post Number: 124
So to answer your question I don't think it has outs, unless ins and outs are the same thing.
Username: Artk
Albany, Oregon
Post Number: 4429
You'll want to use the Y from the L/R pre outs on the mira to the line level in on the sub. Ixos makes a very nice an inexpensive Y.
Username: Artk
Albany, Oregon
Post Number: 4430
BTW that means use both channels of the Mira not one.
Dallas, TX
Post Number: 10114
You should split outputs but not combine inputs. Even with common ground equipment, placing both channels together is not the best route for this purpose. Is this the arrangement you use, Art?
St. Louis, MO
Post Number: 125
I'm not sure if I got the ideal thing, but I stopped at radio shack and got a y-splitter plus a standard rca interconnect. (so splitter into sub and rca from splitter to l/r Mira preouts).
When I plug the RCAs into the l/r preouts (even without plugging other end into the sub) it seemed to rob the Mira of power. Or am I imagining things? It seemed to rob it of a little of its magic.
Do I just need to turn the Mira louder? I'm not sure if this is going to work out, because so far it sounds better w/o the sub. Aside from the quality of the sub which may or may not be hte best, the mains didn't sound as good.
If I want to go the speaker wire route I'll have to do it through some kind of banana plug that can accept two speaker wires at a time. Two speaker cables won't fit in the Mira speaker outs.
Username: Arande2
Extreme SQ FTW
Post Number: 2115
Isn't that their cheapest sub?
St. Louis, MO
Post Number: 126
It's cheap. But I got it for basically free, so it's worth a shot.
I tried plugging into just one of the preouts and I think that actually helped. The mains sound better.
Username: Arande2
Extreme SQ FTW
Post Number: 2118
Wow we live REALLY close to each other...
Username: Artk
Albany, Oregon
Post Number: 4436
Jan, I have a REL and use the speaker level with the neutrik speakon connection. In the past I usually use the L/R preouts to L/R line in.
Speaker level is more ideal MT as it's the connection of choice for some great subs like REL and Vandersteen. My Era also sounded better that way.
Username: Artk
Albany, Oregon
Post Number: 4437
I was mixed up Jan and went and looked at my adaptor and it was a homemade adaptor with a summing circuit...oops.
Dallas, TX
Post Number: 10115
I would advise against summing L and R channels through a simple "Y" connector. As I said, they are fine for splitting a single signal into two outputs but not for combining two outputs into one input. If you want to put two channel outputs into one channel input, you'll need a summing circuit of some kind. Typically you would use a stereo to mono transformer. You can call these folks, http://www.hlabs.com/technical/crossovers/ , they have units with stereo in to mono out that are quite reasonable.
If the amplifier can take standard banana plugs, you can buy stackable bananas that allow a single cable to be used in each plug and one plug piggy backs into the open end of the other.
You'll have to experiment with the sub to find the best placement and crossover for the front speakers. Make certain the sub is in phase with the front speakers.
St. Louis, MO
Post Number: 127
Thanks Jan.
I see no reason standard bananas wouldn't fit the Mira, do you Art? So far I've just been using bare wire.
Username: Artk
Albany, Oregon
Post Number: 4440
I'm using standard bananas on mine for my van den Hul speaker cable.
Home > Message Board > Home Audio > Subwoofers > Archive through June 24, 2007 > Connecting sub to rega mira preouts [ « Previous ] [ Next » ]
