Thread: NAD 3125 or 3150 |
| Posted on Sunday, June 15, 2003 - 12:52 pm: |
I'm buying my first amplifier and I'm just wondering if anyone's heard either of these amps. I'm sure the quality is fine, but what about things like power up sounds? What's a good price to pay for them, they're both on ebay but the price is over $50, think that sounds good or do you think a better deal will show up soon? Thanks |
Unregistered guest |
| Posted on Tuesday, July 20, 2004 - 12:39 pm: |
i have a NAD 3150.. and itīs a bit old now, you know^^ but i never had problems with it, and it plays great! but i will reccomend you to get an nad 2150 to it, and bridging them.. GREAT power-output... i think itīs 170 watt in 8 ohm each channel, but if you use the nad 3150 for itselves in 8 ohm, itīs 60 watt.. 4 ohm, 100 watt, 2 ohm, 200 watt. if you need more info, mail me! |
