Home > Message Board > Home Audio > Subwoofers > Archive through June 24, 2007 > Connecting Sub-Woofer to NAD C350 2 c...
Author Thread: Connecting Sub-Woofer to NAD C350 2 channel amp.
Username: Varney
Birmingham
England, UK
Post Number: 460
Is this possible, without a dedicated subwoofer output on the amp?
Two, fine quality, screw-down binding posts, with banana facility. Bi-wired to pair of Gale 3030, two way speakers.
How does it work; where does it go and can it be done with a 2 channel amp, without blowing it up?
Thanks,
V
Username: Nuck
Post Number: 6476
Varney, the sub has speaker level inputs, paralleled to the main speaker leads.
Username: Varney
Birmingham
England, UK
Post Number: 461
What...? You mean, you connect the sub to the amp, then run the other two speakers off the sub?
V
Username: Nuck
Post Number: 6498
Possibly, but not ideally.
The sub just 'scabs' a full range signal from the speaker leads (not affecting the impedence load the amp sees)and allows it's own XO to deliver the bass, usually via a frequency selector on the sub.
Badda Boom Badda Bing.
Home > Message Board > Home Audio > Subwoofers > Archive through June 24, 2007 > Connecting Sub-Woofer to NAD C350 2 c... [ « Previous ] [ Next » ]
