Thread: Integrated amp for 901's.. |
Bronze Member Username: Shane24
Post Number: 42 Registered: Mar-07
| Posted on Saturday, March 24, 2007 - 10:47 am: |
hey guys, in the 1000-1500$ area which integ amp would be the ideal amp for a pair of 901's used soley for music... and of 150watts per channel. for hard rock, drum&bass, trance,, basically something with good deep bass... and ofcourse overall sound.... i heard them driven with a onkyo9755(150watts)... and nad M3.. and also nad c372.. m3 was stunning.. amazing sound but expensive.. which would be a better choice.. or anything else in the 1000-1500 range... |
Silver Member Username: Gavdawg
Upstate,
New York
Post Number: 460 Registered: Nov-06
| Posted on Saturday, March 24, 2007 - 03:38 pm: |
I would make sure it has a tape (monitor) output to make sure you can use the EQ, or they will sound like schitt and that is putting it mildly. What kind of sound are you looking for first? |
Post Number: 43 Registered: Mar-07
| Posted on Sunday, March 25, 2007 - 02:16 pm: |
well, sound with depth,, and sure as hell i want deep bass... living room is quite large enough.. to handle that kinda sound... |
Post Number: 44 Registered: Mar-07
| Posted on Sunday, March 25, 2007 - 02:18 pm: |
i'll keep that in mind regarding the tape(out).. thanks.... |
