Thread: I need some help? |
Bronze Member Username: Darrenmc
Winnipeg,
Manitoba
Post Number: 20 Registered: Mar-04
| Posted on Thursday, March 22, 2007 - 10:01 pm: |
Originally I was posting in the receiver thread and was looking at upgrading my Onkyo TX-SR701 to something in the $1000.00 - $1500.00CDN range (NAD T753/63, (Marantz SR6001/7001), Denon AVR2807, but I'm not so sure that may be the right thing to do? Maybe spending a $1000.00 - $1200.00CDN or so and upgrading my front speakers would give me better results? I just bought a NAD C542 player and listen to audio/movies about 50/50. My current gear is the Onkyo TX-SR701 a/v receiver, NAD C542 cd player, Acoustat Trans Twin Nova 200 power amp, and Angstrom Modular 2's(Front), Modular 4's(rear), Modular 8's(subs), and 6C Centre Channel. http://www.angstromloudspeakers.com...ar_showroom.htm. Room dimensions are 15X11X7. I wouldn't want floor standing speakers as the sub's act as stands(save some money) and was looking at a little bit larger bookshelf speakers. I have access through my dealer to Paradigm Monitor 5's/Studio 40's/Signature 4's, Monitor Audio BR2's, KWF 201's, Focal.JM Lab 908's, and Acoustic Energy Aelite 2's. I'm not sure which of these $$$ wise are in the $1000-$1200CDN range? So would you suggest change the speakers, if so, what would you recommend, or stick to my original thought of upgrading the receiver? Any thoughts would be appreciated. Thanks in advance. |
Platinum Member Username: Project6
Post Number: 13533 Registered: Dec-03
| Posted on Thursday, March 22, 2007 - 10:39 pm: |
Outlaw Audio Model 1070 http://www.outlawaudio.com/products/1070.html |
