Thread: Sub for sansui amp |
Bronze Member Username: Shane24
Post Number: 15 Registered: Mar-07
| Posted on Wednesday, March 21, 2007 - 07:10 am: |
when it comes to subs... which brand stands out... or known for good subs.. Could anyone suggest a sub of about 250rms, for a sansui amp of 100wts per channel.. i had velodyne in mind.. ur expert opinions guys... (500$ budget) |
Gold Member Username: Arande2
Extreme SQ FTW
Post Number: 1981 Registered: Dec-06
| Posted on Wednesday, March 21, 2007 - 09:37 am: |
It depends on if you want it to be loud or have extension. And when you mean amp if you mean an amp or receiver. Velodyne is fine if it's receiver, but if not, and it's an amp, then I like these subs. www.ficaraudio.com |
Silver Member Username: Stefanom
Vienna,
VA
United States
Post Number: 436 Registered: Apr-06
| Posted on Wednesday, March 21, 2007 - 10:46 am: |
Hsu Research has a lot of options in your price bracket if you are open to internet direct. All of their models would spank their correspondingly priced Velodyne counterparts in most if not all measurable aspects of performance. They are reputed to sound real good too  |
Post Number: 19 Registered: Mar-07
| Posted on Wednesday, March 21, 2007 - 12:24 pm: |
yeah, i mean integrated amplifier.. thanks anyways.. |
Platinum Member Username: Project6
Post Number: 13516 Registered: Dec-03
| Posted on Wednesday, March 21, 2007 - 12:28 pm: |
I second the HSU subs. Well within budget. |
Extreme SQ FTW
Post Number: 1983 Registered: Dec-06
| Posted on Wednesday, March 21, 2007 - 05:23 pm: |
Yes^^ |
