Thread: American(north america) v/s European speakers which make better spks? |
New member Username: Shane24
Post Number: 7 Registered: Mar-07
| Posted on Monday, March 19, 2007 - 09:18 am: |
North America make good speakers, with a lot more punch and bass... and have found that spks from europe are more suited for classic, jazz and related... being more on the high-end level and also far expensive.. Conculsion- NorthA speakers are more enjoyable, kickass type... and less money for good sound with a lot more depth.................(and durable also...) |
Gold Member Username: Touche6784
Post Number: 1180 Registered: Nov-04
| Posted on Monday, March 19, 2007 - 04:40 pm: |
and how did you come about this conclusion? MLs are made in the US and those are great for just about all music, so are magnepan. i am sorry but that is a really bad generalization of speakers. |
Gold Member Username: My_rantz
Australia
Post Number: 1280 Registered: Nov-05
| Posted on Monday, March 19, 2007 - 06:28 pm: |
Hey Shane, if you already knew the answer why did you ask the question? Just one thing - you're wrong! |
Platinum Member Username: Project6
Post Number: 13496 Registered: Dec-03
| Posted on Monday, March 19, 2007 - 07:34 pm: |
Paging Randy Warren! |
Gold Member Username: Artk
Albany,
Oregon
Post Number: 4335 Registered: Feb-05
| Posted on Monday, March 19, 2007 - 08:30 pm: |
Yep...you're wrong! Berny be careful what you ask for . |
Gold Member Username: Frank_abela
Berkshire
UK
Post Number: 1956 Registered: Sep-04
| Posted on Tuesday, March 20, 2007 - 11:31 am: |
Both sides make good product and export to each other. There is something of a divide between the two since most speaker companies (and indeed specialist HiFi companies) are not global in size. For example, B&W is the biggest independant speaker manufacturer by turnover and their turnover is at least an order lower than the likes of Sony. This means the manufacturers have a 'local' take on their products. Regards, Frank. |
