Home > Message Board > Home Audio > Amps > Archive through April 07, 2007 > Dvd player sound lacking while playin...
Author Thread: Dvd player sound lacking while playing music?
Username: Buckstar
Can anybody tell me why my DVD player lacks depth (flat, lacking bass) while listen to a cd or watching a movie? If I watch a show thru my direct tv receiver the sound is so full of depth and is incredible. Is there any DVD players you would recommend for listen to cds?
Thanks!
Relevant Product Info
Username: Gamerdude
Ontario
Post Number: 439
Cables or just a cheap dvd player?
Username: Nuck
Post Number: 6382
Both. Brian, look for Oppo players, they seem to have a good following on a budget.
If the budget is more flexible, the options are a bit higher.
Tell us what you have, and your usage?
Username: Buckstar
Nuck - This is my set up for listening to music in stereo. DVD player is Samsung HD-931 conected to Onkyo receiver TX-NR900 by a Acoustic Research Digital Co-axial Audio wire. I'm using the Onkyo receiver as a pre-amp that is connected to a Yamaha M-65 amp. Speakers are Polk RTI150 using Monster Cable Z2 Bi-Wire. Not sure what RCA cable I have running from the Onkyo to the Yamaha.
Thanks in advance!
Brian
Username: Nuck
Post Number: 6400
Brian, a cd player is required for you now.
Keep the dvd player, of course, but try a cdp when you can.
Do you run a sub?
Username: Buckstar
Nuck, I have a Polk PSW505 sub woofer, not really a fan. Do you have any suggestions on cdp and rca cables? I appreciate your help!
Username: Nuck
Post Number: 6413
Brian, the budget is a factor here.
I see no need to overdo the player, just get the source on track.
I would suggest maybe a Nad player.
Like the 325, as opposed to the 542.
Yes, an entry level Nad will open your ears a bit.
Username: Buckstar
Nuck, Thanks for your input!
Brian
Username: Nuck
Post Number: 6424
Brian, stick around.
Home > Message Board > Home Audio > Amps > Archive through April 07, 2007 > Dvd player sound lacking while playin... [ « Previous ] [ Next » ]
